Question about Sharp AR-507 Copier
AR 336 Code f2-00 - Sharp AR-507 Copier
  • 87 Answers
SOURCE: Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Posted on Jan 04, 2009
007tech
  • 95 Answers
SOURCE: I have a Sharp AR-336 with an error code of E7-11.
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Posted on Mar 21, 2009
007tech
  • 95 Answers
SOURCE: I have a Sharp AR-336 that's showing me F1-00
F1-00 is a communication error between the copier and the finisher. It could be a loose connection (wire that connects finisher to copier) or it could be worse like a failed board. It could be the finisher board or the PCU board on the copier.
Make sure the finisher cord is firmly connected to the copier.
Make sure the copier is not plugged into the same wall outlet as another piece of equipment that might be drawing excessive power. do not plug into a cheap surge protector with other items.
If problem persists call a tech.
Hope this helps
Posted on Apr 17, 2009
  • 67 Answers
SOURCE: HAVE A SHARP AR-336 WITH A CODE H3-00
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Posted on Apr 21, 2009
Cogz
  • 1326 Answers
SOURCE: salut je cherche solution par rapport à un
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Posted on Jan 23, 2010
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
Jan 22, 2010 | Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  6. enter 14
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
Mar 19, 2009 | Sharp Office Equipment & Supplies
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-507 Copier Logo
14 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
