Question about Kenmore 800 7983 Dryer
How to replace dryer belt on Kenmore 800 series
jaballou
  • 63 Answers
SOURCE: dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Posted on Dec 09, 2008
jsrock516
  • 5911 Answers
SOURCE: i have my kenmore 80 series dryer apart, and i am
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Posted on Oct 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Posted on Nov 16, 2009
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
Posted on May 24, 2010
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
The loud screeching noise is either the belt pulley or one of the 2 wheels that support the drum. There's quite a bit of disassembly to reach them.
Aug 11, 2017 | Kenmore Dryers
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
My Kenmore 800 series dryer won't start when i push the start button. It does start to spin but stops after i release the start button. Any ideas what the problem might be??
This dryer has a broken belt switch. If the drum turns then the belt is not broken but the broken belt switch could be. The start switch itself could be the problem. This video shows how to get into your machine:
Sep 02, 2010 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore Series 90 drive belt
Access to the belt may be from the front.
Feb 25, 2018 | Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 800 7983 Dryer Logo
271 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
