Question about Proform Exercise & Fitness
Proform 400c treadmill trips when start button pressed
Treadmill turns on but when you go to start walking it trips the electricty
  • lisa Ryan Jan 11, 2013
    the motor is working fine as i got a man to look at it so he thinks it is the motor board which is triping the electricity. so might have to replace this
    Top Expert:
  • Proform Master
  • 12,223 Answers
Step 1:
see the video and lube deck beltg+rollers bearings.
and test again. if there are o.k . Fine
If the problem persist.time to replace the old deck board complete.
However you must sure and test the following:
Step 2:
test the input voltage motor: if there are the motor NEED repair, See my personal TIPS for motor help.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagrams attached.
Step 3:
proform 400c treadmill trips when start button pre - 1_9_2013_5_08_47_pm.png1_9_2013_5_09_29_pm.jpg
Posted on Jan 09, 2013
SUPERMAN_B_1
  • 294 Answers
SOURCE: total blackout...neither motor or display
IS THE SAFTY CARD INSTALLED ? MOST TREDMILLS HAVE A SAFTY LOCK OR CARD THAT HAS TO BE IN OR READING FOR THE SYSTEM TO START
Posted on Apr 12, 2009
  • 64 Answers
SOURCE: Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Posted on Jun 08, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
  • 40 Answers
SOURCE: My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Posted on Nov 01, 2009
I have a 995 sel treadmill.so im walking on the treadmill for a few minutes and all of a sudden it stops working.then i get off the treadmill and the treadmill starts working just fine, i go back on it, it...
1) Well examine the Lube of walking belt, DO it if you are NOT, must be every 40 hours of training. VERY IMPORTANT.
2) see if the Walking belt is tight? Normailly you must Lift with his finger 2-3" of Hight, IF NOT see Video. How To Adjust Treadmill Belt
The thermical relay tripped from the motor to due this problem.must wait for Normal condition, for elevated temperature.
3) See the drive belt of belt motor is tight, loose the Bolts motor and the deflectin will be 1/8" tight again bolts,
4) If after doing all the steps before,THE problem persist, Replace the Controller Board Motor.
Oct 24, 2017 | Exercise & Fitness
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
Runs without load
It either needs a walking belt/deck or a motor.
Mar 04, 2014 | Horizon T901 Treadmill Walking Belt
I have the 1750 NordickTrack Treadmill and the screen is "froze" on the SD or WiFi screen. I tried pushing the stop button, shutting off the power, and even unplugging the power cord and it still shows...
try this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Sponsored Links
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Circut board trips electricty board
Treadmills are machines with a considerable pull of electricity. Make sure you are operating on a dedicated circuit.
Most users have the machine plugged into a spare bedroom outlet ehich is either not dedicate (power source spread out to more then one outlet) or is a GFI outlet (Ground Fault Indicator).
These outlets are used so homeowners do not overload an outlet in an area where a resident will sleep and be in danger of a fore or death.
Usually in the first few pages of your owners manual it will give you the requirements for your machine.
You can run an extension cord to another room with a dedicated outlet, but the extension cord does not transmit all the power coming out of the outlet and will eventually lead to other issues, usually electrical issues within the machine.
You can use a multimeter to see what else could be the issue with your outlet, but will want to consider having an electrician put in a dedicated outlet.
Jan 05, 2013 | Proform 400 CT Treadmill - Treadmills
My profrom 480e threadmill is tripping as soon as I start it.The kids palyed with red stop button. I put the stop button back, but still it trips.How do i fix it.
Hi
Looseness or discolorations of the prongs on the plug or the terminals in the wall or extension indicate a weak connection. A weak connection lowers the voltage to the treadmill and causes the motor to work harder. With low voltage the motor draws more amperage and causes the circuit breaker in the treadmill to trip.
Another cause for circuit breakers to trip is the belt needs lubrication. Check for belt lubrication and ease of movement. To test the walking belt lubrication, do not turn the treadmill motor on. Set the elevation to the highest level. Stand near the front of the walking belt. Push yourself firmly toward the rear of the treadmill. If the belt is properly lubricated the belt will take you to the rear edge of the treadmill and dump you off on the floor. If you move and stop, the belt needs lubricating.
Also check this related link:-
http://www.livestrong.com/article/404896-my-proform-treadmill-wont-start/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 05, 2011 | Sport & Outdoor - Others
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
158 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
