Question about Canon DR-5010C Scanner
Canon DR-5010C Scanner How to get rid of the 4 zero's at the end of the naming convention?
I scan a document into the scanner naming it JC8 and it created a PDF file as JC80000. How do I get rid of the 4 zero's at the end of the naming convention?
  • kmoghjih
    kmoghjih Jan 14, 2013
    The scanner utilizes CapturePerfect and adds the four zeros at the end of the naming convention after it has been scanned into CapturePerfect.
  • 490 Answers
The 4 zeroes at the end are added on purpose. If you are scanning a set of documents, say 11 pages, to maintain the sequence the scanner scans them as abcd0001, abcd0002 till abcd 0011. Without 4 zeroes, the first file will be abcd1, abcd2....abcd10, abcd11. Now in the Computer the sequence will be abcd1, abcd10, abcd11, abcd2 till abcd9, altering the sequence. If you are scanning into PDF, the scanned images will be added automatically maintaining sequence.
S. Mohan, India
Posted on Dec 30, 2014
4 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: how to get rid of the 4 zero's at the end of the naming convention?
The scanner allows you to scan in batches and you can select a convenient name for a batch. If you start the first batch as 'A', then the first image will be 'A001.tif' , second as 'A002.tif' etc. If the next batch is 'B', then it will be, B001.tif, B002.tif etc.
S. Mohan
Posted on Nov 08, 2008
mohanchennai
  • 490 Answers
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Posted on Mar 28, 2009
hawaiianb283
  • 24 Answers
SOURCE: Canon DR-9080C Scanner all of
Sounds like the shading compensation strips may be dirty and/or sticking. Otherwise the scan sensor is going out.
To check and clean the the shading compensation strips:
Open the feeder up all the way and hold down the red stop button.
...in about 5 seconds the upper and lower shading compensation strips will pop up.
They may be getting stuck and not popping out all the way (about 1/2")
Clean them up with a small brush and a lint free rag with alcohol.
If the shading sensor strips aren't popping out all the way, this will cause the problem you described, so clean them up and repeat this several times.
(They pop up during the document scanning process)
If they still aren't popping out after cleaning them up, then there may be a mechanical problem with the mechanism.
Hope this helps! You may need a tech.
I am in Dallas, Texas if you are local to me I can put an eye on it.
Posted on Nov 29, 2011
5010C scanner won't skip blank pages
We had this problem and discovered it was caused by a small piece on the glass. Once the glass was cleaned, the blank pages were skipped.
Sep 11, 2012 | Canon DR-5010C Scanner
I just changed the rollers in my Canon Dr-5010c and now the papers won't pull into the scanner, help!
Try 'page-counting', if this works, the scanner is okay. Fan the documents and loosen them, ensure the end touching the roller is crisp and not bent/folded. You can also try a different set of documents to eliminate paper related problem.
S. Mohan, Chennai, India
Nov 17, 2010 | Canon DR-5010C Scanner
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
Apr 01, 2010 | Canon DR-5010C Scanner
Canon DR-5010c feed roller does not stop running after documents
Please blow air and clean the sensors. There could be a small piece if paper causing this. The scanner must be assuming that there is paper.
S. Mohan
Jun 11, 2009 | Canon DR-5010C Scanner
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Apr 16, 2009 | Canon DR-5010C Scanner
Mar 19, 2009 | Canon DR-5010C Scanner
Scanner Canon 5010c
This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
S. Mohan
Jul 28, 2008 | Canon DR-9080C Path-Through Scanner
DR-5010C scanner yellow line
First clean the glass thoroughly using IPA (Iso Propyl Alcohol) Dont use any solvents. If you are getting the same result even after this, there could be a module problem.
S. Mohan
Mar 31, 2008 | Canon DR-5010C Path-Through Scanner
Canon Dr-5010C Scanner to Pc problems.
Are other formats, like JPG, working okay? Unselect multiple pages so that you get on image per sheet. Reinstall scanning software after a 'scandisk' command.
S. Mohan
Mar 04, 2007 | Canon DR-5010C Path-Through Scanner
Canon DR-5010C Scanner Logo
151 people viewed this question
old marine
old marine
