Question about Hotpoint 1578h5 C00209186 Creda Crusader Tumble Dryer Belt
Our Creda Crusader tumble dryer is dead. Changed the fuse but still dead.
Having worked perfectly for about 10 years, our tumble dryer is stone dead. Any ideas if this is terminal or if it can be fixed please.
  • Christine Fadley Jan 11, 2013
    When we moved it yesterday it suddenly burst into life and then died again, so we are thinking that there is a loose connection inside. Any ideas where that might be? Thanks for reading this xx
  • 108 Answers
Hi check around timer allso door catch
Posted on Feb 14, 2014
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: The start button on my creda tumble dryer model
You should be able to access the button by removing the top cover.
Please rate my solution.
Thanks.
Posted on Nov 21, 2009
  • 2501 Answers
SOURCE: the tumble dryer trips out
It sound as though it is overheating.
This may be caused by a reduction of air flowing through the machine.
Check all the filters and the out pipe for blockages that would restrict the air flow.
Posted on Dec 14, 2009
  • 160 Answers
SOURCE: how can i at home fix my hot point ultima tdc970
power off unit and unplug... unscrew rear heater panel and 2 screws securing heater... there are 2/3 stats attached to the top of the heater unit... one has a small hole in it, this is the resetable stat.. into this insert carefully a pin or paperclip till a clik is heard.. reassemble in reverse..
check condensor and door filter for blockages.. fire up again and hopefully back in action
Posted on Dec 22, 2009
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Creda compact 3 37301 tumble dryer pull down door. Not heating only rarely, have changed the element. It heated a little while but starts blowing cold air. Drum is working and fax at back
I would suspect thermal fuse, easiest way to test is to tape wires together and start dryer. Safety note if left like this it will start a fire. It is located on the back of the dryer and has two wires connected to it. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Usually, failure of a thermal switch is caused by extreme heat: meaning that the dryer is not venting properly, clean dryer of lint inside and outside as well as the vent tube. Good Luck Tim
Dec 16, 2010 | Dryers
How to replace a crusader tumble dryer belt
this is a good website, hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 16, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Oct 18, 2009 | Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Creda t602cw condeser tumble dryer
how do i replace the belt? i'm having a hard time just getting the back of the dryer off!
May 18, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Hotpoint 1578h5 C00209186 Creda Crusader Tumble Dryer Belt Logo
283 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
