Question about Sharp AR 201 Copier
Sharp AR201 Polygon motor lock
The massage on display is L6
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Displays E7. Meaning? Fix?
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
Posted on Jun 06, 2008
  • 120 Answers
SOURCE: AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Posted on Jun 15, 2008
M2Tech1
  • 313 Answers
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
  • 17 Answers
SOURCE: looking for part number for Sharp AR5132 polygon
Ploy for the AR-5316 copier is RMOTN0022QSPZ
AR-5132 I think I still have the parts guide at work will look next week. I may also have a pulled working laser unit. I can check with my office for a price if you want and if I can find it.
Posted on Nov 21, 2009
SHARP AR-M236 CALL SERVICE CODE L6-10
Hello I found this for your error code.
Code
L6-10
Description
Polygon motor lock trouble
The polygon motor does not rotate. The motor lock signal is detected for 6sec or more after the polygon motor rotates. The motor lock signal is detected for 1sec during rotation of the polygon motor.
Causes
Polygon motor unit failure Polygon motor connection, harness trouble or disconnection MCU PWB failure
I would unplug the unit for a minute and let it cool, then restart it and see if it was a temporary glitch or if the polygon motor has ceased to funtion. You might try to see if the wiring harness has come loose, otherwise you are looking for a new polygon motor.
Here is a copy of the service manual.It also suggests running a SIM 61-1.
https://www.manualslib.com/manual/1065394/Sharp-Ar-M236.html?page=100
I found a replacement motor for the machine, to give you an idea what it will cost to replace, keep in mind if you don't have the ability to replace this yourself you will have to call a repair tech to come in and do it and you may expect the cost for that to be at least the same as the motor.
http://www.precisionroller.com/motors-for-sharp-arm205/products.html
Hopefully it isn't a motor failure. Good luck.
Oct 18, 2017 | Sharp Office Equipment & Supplies
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
It displays l6
L6 = Polygon Motor Lock Detection
The Polygon Motor spins the mirror which writes the laser signal to the drum.
If switching the machine off/on doesn't cure the error code the only other thing you can do iw just check that all the connectors are plugged in correctly. Polygon Motors do fail and when they do all you can do is replace them. Quite often they will screech or rattle in the run up to failure.
Hope this helps.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 207 displaying L6-10
HI for L6-10 you must change the polygon motor and if you are unlucky may change all the laser unit but usually with the polygon motor it is ok
Mar 22, 2010 | Sharp AR-207 Copier
What does error code L6-10 mean on a Sharp AR-235 copier? Would it be worth fixing? Thanks
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 24, 2010 | Sharp AR-235 Copier
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
rotate normally.
Cause The LSU connector or harness in the LSU is
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Photocopier Sharp ar201 not working
L6 - Polygon Motor Lock: The lock signal (the specified rotation speed signal) is not supplies within the specified time (about 6 seconds) after starting the polygon motor rotation. LSU connector disconnection of harness disconnection in the LSU. Replace LSU.
Aug 01, 2007 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
