Question about Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer
My Cuisinart Coffee on Demand DCC-3000 is leaking coffee from the shower head
As soon as the coffee is brewed it starts dripping from the down-spout..where the coffee should come out only when the lever is pressed to pour coffee.
  • J. Hardman Jan 11, 2013
    It may not have been the 'showerhead' that was leaking. It was the spout where
    The spout where the coffee comes out was leaking. I put a vinegar/water solution through the machine to clean it. Lots of big chunks of 'black' came out. I rinsed the pot in clean water and the leaking has stopped .. for now!!! Thank you for your time!
Coffee Maker is leaking
mine was not same make but the upper water tank was plastic and seems they fracture when getting hot too many times .Bunn would not provide a replacement tank so it was buy NEW
Jan 08, 2015 | Cuisinart DCC-3000 Coffee-on-Demand 12-Cup...
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Aug 29, 2009 | Cuisinart DCC-1200 Coffee Maker
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Coffee pot won't turn on
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart DCC-2000
Conair DCC-3000 - Cuisinart Coffee on Demand DCC-3000 Brewer Logo
809 people viewed this question
Top Conair Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Conair Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
