Question about Blenders
The sunbeam blender glass jug and cutting blades assembly will not undo and come apart as the rubber seal is dirty and needs to be cleaned !!
I am unable to separate the jug and base to clean the rubber seal as its really difficult to unscrew them apart !!
    Sergeant:
  • 475 Answers
SOak them in hot water with some dawn soap maybe that might do the trick.
Posted on Jan 11, 2013
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
SOURCE: Broken glass jug - Sunbeam blender PB7600
I have one, marlene 0409465707
Posted on Feb 27, 2010
SOURCE: Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Posted on Mar 30, 2010
  • 29 Answers
SOURCE: Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Posted on Jun 30, 2010
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
I can't find find just the rubber seal, where can I buy it?
The seal is just not available by itself, you need "Blade assy w/ring seal" part number 123250-000-000. Available from Sunbeam at 1-800-458-8407 or online here.
Sep 04, 2011 | Sunbeam 2774 Blender
The rubber ring that goes in to the part where the blades are ,it is broken where can I buy this part?
The ring itself is not available separately, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Sep 02, 2011 | Sunbeam 2774 Blender
Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
Aug 26, 2009 | Blenders
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Cuisinart sealing gasket
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Blenders Logo
88 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
