Question about Frigidaire PLMV169DC Microwave Oven
Frigidaire clock runs fast - Frigidaire PLMV169DC Microwave Oven
  • Frigidaire Master
  • 9,047 Answers
Assuming you're using it in the US and it's not set via the controls for operation on 50Hz, then it may just need a hard reset.
To do that, you would unplug it for about 2 minutes, plug it back in, and try it again.
Posted on Jan 10, 2013
I had the same problem and had to rely on the coffeemaker clock to see what time it was as the microwave would get 15 minutes ahead, drive me crazy and I\'d reset the clock....only to have it happen again.
I tried to ignore it, but the more I tried the more I noticed it ARGH!
Ok, I noticed that there was a plastic (saran wrap) type covering over the whole interface of the control panel. I definitely could not ignore that! so, I picked it off with my thumbnail, reset the clock and the clock has been correct for three days now. And I mean to the second!!! That is the solution.
Posted on Mar 08, 2014
  • William Miller
    William Miller Mar 11, 2014
    The only way this could have been related would be if peeling the shipping protector sheet (probably mentioned in your manual) created a static electricity zap that reset your controller. A ssimple "hard reset" (unluggping for a couple of minutes, then plugging back in) should fix it, as long as it's not in "demo" mode if that feature is present.
  • Donald Bonner
    Donald Bonner Mar 15, 2014
    I actually agree, that seems to make sense at least. Thanks for the "Real" solution. LOL
Have frigidaire microwave and. Every time I try to set the clock it goes back to zero's # lfmv164qfa
That model does not apprear to be a valid Frigidaire US model number.
Did you try unplugging for about 5 minutes, then plugging it back in and trying it again?
It would also be helpful if you could describe in step by step detail what happens.
If you need further help, please verify the full model number from the tag / label and contact me via here.
Oct 12, 2016 | Frigidaire Microwave Ovens
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
FMT 148G1W2 model how to turn the clock off
Good Morning Friend, that's a great question!
The clock display on your Frigidaire microwave (FMT148GW2) may be turned off by pressing and holding "0" for about three seconds. You can redisplay the clock by pressing "0" again. Hope this helps! - Z
Jul 06, 2014 | Frigidaire FGMV174K Microwave Oven
Why would the microwave keep running if we just close the door and no time is set?
Good Afternoon Friend,
I understand that your Frigidaire microwave continues to run, when you close the door and no time is set. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. You might need to set your clock before doing anything else. Put a cup of water inside your appliance and try to heat it up. If you are still noticing your microwave continuing to run, even after no time is set, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Microwave Ovens
Sounds like its running, but will not heat
I understand that your Frigidaire microwave, model# MWV150KBA, sounds like it is running but will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes.
Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button once for AM and twice for PM, enter in the time, and press the "Clock" button again.
Put a cup of water in for about a minute. If the water does not get warm, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your microwave and determine why it is not heating. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Microwave Ovens
How to set clock on Frigidaire FPBM189KF?
You can find the directions on the internet if you look on the Frigidaire website. There should be schematics and diagrams and directions somewhere on the internet. That's if you can't find your original books.
Nov 07, 2013 | Frigidaire Microwave Ovens
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
I need directions on how to set the clock. Can't find the manual
Select "User Pref" upper right corner of keypad, then select from menu "Clock" (item 5), then enter time, select "Start" - you are have just set the clock for Frigidaire FGMV174KFB
Nov 07, 2010 | Frigidaire FGMV174K Microwave Oven
CLOCK
You should be able to go online to frigidaire.com and dowmload owners manual.
Jul 25, 2008 | Frigidaire Mid-Size Microwave
Frigidaire PLMV169DC Microwave Oven Logo
880 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
