Pavillion a705w has broken power button
Three of four legs that hold power button are broken. Where can I get new button?
  • Computers & ... Master
  • 27,725 Answers
5 Suggested Answers
marinos
  • 114 Answers
SOURCE: installing new power supply in hp pavillion a705w
You will see one big connector with 20 pins which goes to your motherboard and fits from only one direction. connect the 4 pins connectors to your CD/DVD rom(s) and hard disk(s). again the connector can be plugged from one side. If you have a floppy drive then you can connect the smaller white 4 pins connector to it.
Good luck
don't forget to rate this solution. if your problem is solved please rate it as solved
Thank you
Posted on Oct 12, 2007
myob247
  • 1342 Answers
SOURCE: HP Pavilion a705w willnot power up
Read this HP forum thread. You may want to try some of the recommendation.
Posted on May 21, 2008
  • 3 Answers
SOURCE: hp pavillion a705w will not boot up
I had the same problem, I unplugged my computer to move it before it had fully powered down. It wouldn’t start and all I got was the flashing lights.
I asked a friend who suggested I remove the power to the motherboard then reinsert it while it’s hot. Here’s what I did. Unplug the computer. Touch something metal so you’re grounded and don’t create a static shock on the motherboard. Now GENTLY pull the 16pin wire harness off the motherboard. Now plug the computer power cord back in. Then GENTLY plug the motherboard back in. With any luck the fan will start up and the computer will begin booting up. It seems to be some type of problem where the power supply doesn’t recognize the motherboard so it doesn’t do anything until it “sees it”? Probably some type of a safety to prevent motherboard burnout?
Posted on May 26, 2009
SOURCE: HP pavillion a705w. Power light
As far as I could figure out, you need a new power supply. I had the same issue
Posted on Jan 02, 2011
We moved the desktop to another location. We powered down and unplugged it. When we plougged it back in there was an alarm that went off then the power button started flashing and continues to do so. We...
hi t could be that your CPU fan is loose or that your RAM(memory) came loose try looking on youtube to see how to put RAM (memory) into pc and make sure your CPU fan is secure....bonnell
Sep 17, 2011 | HP Pavilion a705w PC Desktop
We think there could be a bearing going it is very noisy and the drum seems lose.
It is more likely the bracket that holds the drum to the spindle - oftewn called a 'spider'. This has three or four 'legs' - if you look at the back of the drum you will see the indentations in a star pattern. One or more 'legs' has probably broken and so the drum is no longer able to spin centrally. The spider can be replaced by a washing machine repair engineer. Do not continue to use the machine unitl it is repaired because a loose drum will cause additional damage (mine wore through the heating element).
Mar 01, 2011 | Washing Machines
Integrated 10/100 Network Card for HP Pavillion a705w: My brother-n-law HP Pavillion a705w is dropping it's internet connection after about 2 minutes. We thought it was the Cable Modem Box (Motorola)......
Hello my name is Israel. On your type of cpu your network card is integrated into th emother board. YOu can purchase one and just connect it inot one of the slots. the instructions as well as the software should be included in the package. It will be a very painless installation. You can probably get a dlink network card at Best Buy for about $15. Good Luck.
Feb 15, 2011 | HP Pavilion a705w PC Desktop
What memory do I need to upgrade my hp pavillion a705w
hello
for that particular HP computer, you need this memory module
256MB, PC2700 DDR-SDRAM DIMM memory (32Mx64, DB221AX)
ask for P/N DD234-69001, SHOULD BE ABOUT $20-$25 PER STICK
hope this helps
Nov 09, 2010 | HP Pavilion a705w PC Desktop
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
Installing new power supply in hp pavillion a705w
Good luck
Thank you
Oct 11, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
