Question about Datalogic QuickScan M2130 Wired Wand Barcode Scanner
M2130 yellow keeps blinking
The yellow Power On / Data led keeps blinking when connected to the laptop via USB. This is after initial installation. No codes could have been scanned successfully yet.
  • Erik Aug 06, 2013
    have you solved it ?
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Jul 30, 2008 | Polaroid SprintScan 4000 Film Scanner
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
How can you reset a brother HL-5170DN with out the password either with it connected via USB or ethernet i cannot remember my password
You'll need to reset your printer to factory settings. BE SURE TO PRINT A CONFIGURATION PAGE FIRST.
VIA THE PRINTER CONTROL PANEL
  1. Switch the printer off.
  2. Make sure that the front cover is closed and the power cord is plugged in
  3. Hold down the Go button as you switch the printer on. All the LEDs light up. Keep the button pressed down until the Toner LED lights. When the Toner LED lights, release the Go button.
  4. Hold down the Go button until the Yellow Status LED lights. When the status LED lights, release the Go button.
  5. When all the LED's light, the printer will start warming up. The print server has now been reset to its factory defaults.
Nov 02, 2009 | Brother HL 5170DN Laser Printer
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
Blinking screen, need to retrieve data before formatting
hello there...that's fine you can get a usb data cable, bluetooth ,or memory card reader to transfer your Data to your
computer....
consider visiting a mobile accessory shop you will have all the options there or it might have come with your phone initially
Using a usb cable and card reader is most convinient
Hope this helps
Cheers
May 25, 2009 | Sony Ericsson K600i Cellular Phone
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
Datalogic QuickScan M2130 Wired Wand Barcode Scanner Logo
60 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
