Question about LG 60pk200 60 1080p Plasma Tv 60pk200
My lg 60pk200 will not turn on
The tv power light flashes and makes a clicking sound
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
SOURCE: I have LG 50PC1DR plasma
Hi !..ok you tv problem is in power supply. need be replaced 9 capacitors, (3300mf - 10V) in main power supply board, that fix yu tv..
Posted on Feb 04, 2009
  • 1039 Answers
SOURCE: lg 32lcd tv's - does not power up - flashing green light
Replace any swolen capacitors on power board. If still not working replaced main board.
Posted on Aug 29, 2009
  • 41 Answers
SOURCE: I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Posted on Dec 18, 2009
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
My tv had a few small vertical lines for year, then went black completely. Sound still works, but no picture. What part/board am I looking to replace?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | LG 60pk200 60 1080p Plasma Tv 60pk200
Picture not sharp
What are you running for a signal. Are you putting a digital signal into an anolog tv? Are you coming out of a cable box?
Jan 31, 2013 | LG 60pk200 60 1080p Plasma Tv 60pk200
When I go on input and expect for the the dvd to work but it says no signal Why is that
Try another input and check hookup and the cables being used---if get no disc, cannot read disc etc the problem is in the player itself.
Nov 07, 2012 | LG 60pk200 60 1080p Plasma Tv 60pk200
I am trying to play my game. When I plug the when I plug the red,white ,yellow extention in the AV1 and go on input it does not work it says no signal and I dont understan why I would need signal to play a...
The input is not "seeing" the signal from your game---try another input and make sure connections are correct and the set is switched to the input you hooked up to(they are labeled on the back)
LG shut off by itsself last night Comes on but, green light flashes a couple of times, makes a clicking sound red light comes on then shuts off. The tv also, turns on if i manually press the channel button...
Tries unplug,replug the tv back like an hour later.The tv,now it will resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Try website Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 50PC5DC 50 in. Plasma HDTV
Turn the TV on, clicks back off - no sound, no picture
hello, your power supply has to be repaired and you are looking at $275.00 for this job
good luck
Jun 23, 2009 | LG 42PG20 42 in. Plasma HDTV
LG 60pk200 60 1080p Plasma Tv 60pk200 Logo
388 people viewed this question
Computer Repairing
Computer Repairing
