Question about Canon Service Manual For Ir 2000
I have canon ir 2000 give me error E001 AND E733
WHAT PRO MY PHOTO COPIYER
  • 18 Answers
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
SOURCE: canon LBP5360 printer. giving error code
First check:
Description: The detected temperature of the main thermistor is
245 deg C (equivalent to approx. 2.12V) or higher for 0.5 sec. or
longer.
Cause: Main thermistor defect, DC controller PCB defect
If i have been useful please give me a vote :)
Posted on Apr 05, 2011
SOURCE: USA - COPIERS - IMAGERUNNER 2230 Copier: canon IR 2230 r giving me an error E000024-0001...
eroor 000024-0001 error is found in cannon ir 2870 machine, how is solve the problem
Posted on Aug 25, 2011
  • 109 Answers
SOURCE: CANON IR2016
You have a problems in fixing unit maybe in the fixing film or in the fixing drive
Posted on Oct 28, 2011
bilalkhtak
SOURCE: Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Posted on Nov 30, 2012
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Canon ir 6000 ranning copy machine hang 2minet before e733
Dear
1) Turn off and then on the main power switch. Is the problem corrected?
YES: Check the operation once again; if normal, end the work.
Check Connectors, DC controller PCB
2) Is the connection of the connector (J1015) on the main controller
PCB and the connector (J122) on the DC controller PCB normal?
Further, is the cable between these connectors normal?
NO: Correct the connectors/cable.
YES: Replace the DC controller PCB.
Thanks.
Feb 07, 2015 | Canon imageRUNNER 6000 Copier
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Sir; i have a canon ir 6000i model machine
these is often sympthom when there is fixing trouble, usually when there is error code like E000, E001, E002, E003...
If you want send me e-mail on emma.servis@gmail.com for service manual.
Aug 03, 2010 | Canon imageRUNNER 5000 Copier
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Jul 16, 2010 | Canon Office Equipment & Supplies
Canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Service Manual For Ir 2000 Logo
62 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
