Question about HP Compaq d530 SFF PC Desktop
Hp compaq computer is showing a red light and stop booting
P81/5a#g16
    Scholar:
    New Friend:
  • 58 Answers
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Posted on Jan 16, 2013
4 Suggested Answers
Geodavis
  • 45 Answers
SOURCE: won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
Posted on Oct 29, 2009
  • 366 Answers
SOURCE: i was changing the processor in my hp compaq d530c
try lifting the proccessor again make sure no pins are damaged and place down centred , lock up and try again. make sure board can support this type proceesosr.
Posted on Dec 03, 2009
SOURCE: why will my Hp Compaq dc7700 gives red light and wont boot
usually suggests a major failure internally
motherboard
cpu
maybe power supply
Posted on May 26, 2012
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
How do I bypass or remove the delay upon starting my Yamaha G16 A/E cart?
Not supposed to have a delay. Something is wrong.
Possible causes are Starter/ Gen bad, loose belt or worn, I am thinking this a gas cart? Usually G16 A is gas and G16 E is electric.
Apr 05, 2017 | Golf
Locating solenoid switch on 1999 esteem. Drained radiator last night to fill with antifreeze, then car would not start! Had no problems before. wondering if maybe we pulled a wire loose some where?
depending on how the radiator was drained , ( bottom hose off or tank tap) it is possible that the wire to the crank position sensor was disturbed
run the fault codes to check for other possible wiring problems or sensor failure
Nov 29, 2016 | 1999 Suzuki Esteem
What is the location of crankshaft sensor on 1999 Suzuki Esteem 1.6L?
sorry old post but others will land here and ask this simple questions...its a top question.
why not rent a scan too.
the 1.6 liter is the suzuki G16 engine.
i have vast data on it, and full shop manuals and parts lists.
and lots more.
the G16 has a distributor.
the J18 has NON, called DIS, (distributor-less ignition systems)
the J18 has cops. coil over plugs. times 4.
if it dont start. why not rent a scan tool..
want to work blind with EFI>? why to that and go broke.
why?
The 1999 (1996 and up ) usa cars, all run OBD2 PCMs
and all will scan with any OBD2 scanner made here.
even the $10 on fleabay work, need photos of it working have them. lots.
here is my bud, scanning everywhich way but sunday.
http://www.fixkick.com/ECU/Authority/A_Full_OBD2_scan.html
on an real G16.
looks same on all G16 in all suzuki cars made, with OBD2.
all USA cars do this... ALL.
1996 to NOW.
Jun 11, 2014 | 1999 Suzuki Esteem
Main bearing clearance
its in the fsm.
G13 or G16 engine. they had 2 choices in 1989>?
G16.
(all steps are here, as is link to real FSM)
http://www.fixkick.com/engine/97-motor-pull/bottom-end.html
old post and late.
but google will find it now.
Apr 16, 2014 | 1989 Geo Tracker
Yamaha g16 chatering and smoking
Worn piston rings, piston slap and possibly oil too thin.
Mar 11, 2014 | Computers & Internet
Setting valve timing
no year, no joy.
lots of engines. used, 56 types and 12 on VITS.
if its and old G16? its diffr. from 8v to 16v and is here
and in all FSM for your car, and if USA car, at alldata.com
G16 engines.
Nov 20, 2013 | Suzuki Vitara Cars & Trucks
Atwood G16-EXT won't stay lit
check burners and orfices for cobwebs if ok check pressure
Apr 20, 2013 | Atwood G16-EXT Gas Only XT 10 Gallon DSI...
Hp compaq pentium 4 not booting, light blinks red 8 times
No solution, but I can give an idea of what's wrong.
In the quickspecs for this computer
http://h18000.www1.hp.com/products/quickspecs/productbulletin.html#spectype=worldwide&type=html&docid=13029
nder the expended Technical Specifications section, in the 'Serviceability Features of the system' section, under 'Diagnostic LED Explanation Table', it says 8 blinks of the red LED, repeated every 2 seconds, mean "invalid ROM, bootblock recover mode"
It seems that your BIOS ROM become corrupted. The solution to this problem depends on which BIOS you have. Search "invalid ROM, bootblock recover mode" for possible solutions. Restting the CMOS by shorting the two pins on the m/b might just work, but I doubt it in this case. You may have to get the contents of the ROM from HP and re-flash your ROM. Good luck.
12.April.2014
Feb 23, 2013 | HP compaq dx2000mt pentium 4 2.8g512mb...
HP Compaq d530 SFF PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
