Toshiba washing machine, 8.5kg, model AW-9700S with Fuzzy control. Japanese make bought in malaysia. Its just 2 years old. Every time the machine spins for 9 minutes and stops. Error message E-2 flashes. Water is not draining, no spinning or washing. Can you identify the problem?. Do I need any spares to replace? How much would they cost.
  • margani10 Jan 21, 2009
    After careful checking its noticed that after 9 minutes spinning, water gets drained (there is no valve blockage). But after that its not running. Actually it should go into the next mode of rinse or spin after taking water. Thats not happening.
    Sergeant:
    Champion:
  • 435 Answers
Check if the outlet valve is working. May be its faulty...
Posted on Jan 21, 2009
    President:
  • 2,559 Answers
The problem is the control board is malfunctioning and needs replaced.
    President:
  • 1,990 Answers
Welcome to Fixya! It sounds like the Timer and Timer Relay may need Replacing.
  • 3,037 Answers
Hi margani10
Alright, since I live in the US, this product is not familiar with me but when on spin mode this is what it says to do.
Drain the water from the tub. (Open the lid. After "E2" displays, power off.)
If it doesn't work, let me know but I haven't found anything else so far and so will have to call someone if this doesn't help. Let me know.
bestdarngood
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
sorry no info at the moment yet on error code E-2. on the drain issue, corrective action involves opening the bottom/kick panel and or any of the cover for that purpose and gain access to the filter, sump/bowl, valve, impeller, pump motor and hose (kinks/blockage). A bit of a messy job but relatively esy assuming all it requires is cleaning assuming no parts need replacing.
Good luck and thank you for using FixYa.
    Sergeant:
    Scholar:
  • 199 Answers
These days, most washing machines are controlled by software in computer-type modules. If a fault occurs, the washing machine will often abort the program and display an error code. This could be in the form of a letter and number (such as F10 or E2) or by flashing neon lights. If your washing machine is aborting the program, and lights are flashing, make a note of which neon(s) are lit up or flashing. This is invaluable information which can be reported to an engineer. For information on other washing machine error codes, see Washing machine displays an error code
  • 177 Answers
Hello and welcome to FixYa!,
The Manual should help out.
I will try to find one for you!
Hope this Helps --P3NGYJ03
  • Jackson Henney Jan 21, 2009
    OK CONTACTED TOSHIBA AND THEY SAY
    E2 is displayed when the lid is open during spin cycle.
    If E2 never dsiapear even after closing the lid, your
    washer can be broken."
  • 8,197 Answers
Your drain line is pluged some where from the pump to the drain
  • Jyackle5
    Jyackle5 Jan 21, 2009
    Sounds like the control board is damaged and needs to be replaced
    Scholar:
  • 160 Answers
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
    for more information check the link below:
    Sergeant:
  • 378 Answers
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
just unplug the unit for sometime then on it again and checkout.also check out if any thing blocking the drum to spin internally.
if its internal fault can cause to near to $50
abnd the required parts can be received from
www.repairclinic.com
Toshiba washer malfunctioning model aw 9770 sb showing an error of e7-4
Owner's manual troubleshooting may give you an answer.
Google make model possibly serial year. You may find someone with the same problem and the solution. Usually MFG customer service is helpful. If fairly new local dealer may be helpful.
Mar 08, 2015 | Washing Machines
User manual for Toshiba Automatic Washing machine
Contact Toshiba diectly to request a user manual for your washing machine.
Sep 13, 2014 | Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
We bought electrolux washing machine ewf 85761 in penang malaysia, before we brought on board ship test is done on the store,the washing machine is in good condition..Then we brought the washing machine on...
Just as a wild guess, the control circuit in the washer may not work with 60 Hz shipboard power. The motor probably is not affected. You must be getting awfully tired of hauling that washer back and forth!
Sep 07, 2012 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
How to get a spare part of a toshiba semi automatic washing machine
Hi.
It depends on your location. To start you find the local Toshiba support number in your machine's owner manual.
In UK you can also contact: Currys partmaster.co.uk
If you are located in Australia/NZ you can also order from: Toshiba Washing Machine spare parts.
In Malaysia and other Asian countries you can contact: Toshiba Malaysia
Hong Kong: Service & Maintenance.
There are more distributors. Details depend on your location.
Regards.
Ginko
Aug 22, 2011 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
1,403 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
