Question about JVC PD-42WV74 42 in. Plasma EDTV
Hello, I have a plasma JVC TU42D30ES 107, the external tuner box is out of service, do you where i could buy an another one.
Hello, I have a plasma JVC TU42D30ES 107, the external tuner box is out of service i have the sound but no image, the screen still works but only if i plugg the tuner. tuner image : http://plasmatvbuyingguide.com/plasmatvpics/plasmatv/jvc_08.jpg do you where i could buy a new tuner Thank you Yann
5 Suggested Answers
  • 302 Answers
SOURCE: jvc plasma monitor with picture but no sound from internal speakers
OK i would check the obvious first. Check your controls to make sure the speakers are turned on. The next thing I would check is your speakers you would have to take them out and inspect them physically and if you can take the out and plug them into a receiver or something that has oudio out. If all that is good then You signal board migh be bad.
You can get parts for that tv at www.interliquidparts.com
Posted on Feb 25, 2012
  • 298 Answers
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Posted on Apr 01, 2009
  • 273 Answers
SOURCE: TV was playing fine (then we had a power surge) and now I do not get the digital cable signal on any input (TV, Video 1, 2, 3 , 4 or 5). The TV plays great when I hook up my DVD player to it.
try safemanuals.com for online manuals or elitezoom.com
Posted on May 30, 2009
SOURCE: need a display tuner jvc pd-42wv74
I have a 108cm JVC plasma tv model no VM-42V31BUE, was wondering were i could buy a new tuner box, the one i have was working and now it does not turn on, my email is jmg5117@gmail.com
Posted on Jul 07, 2012
Can jvc vm-42wx84 be used as a monitor without tuner
This is a screen with a media box. The box has two connections to the display panel. The first looks like a DVI connector. The second is the proprietory control port connection. This is how the set receives commands about brightness, contrast etc, scaling, aspect ratio. It might even control such basics as power on/off.
You could try the panel just with a DVI connection, but you will have to make sure that all sources are scaled to the panel's native resolution (1024x768) before they reach the screen. This is part of what the media box does. You might be okay if you're driving the panel direct from a PC graphics card. But if you want to run it with a variety of different sources then you really need to use the JVC media box.
I can't say if the Hitachi media box would work.
Sep 10, 2014 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Where do i plug my cable cord into on my 42 inch sylavania
Hello - The fact is that your TV, as a HDTV ready device, is really a display monitor that does not contain any TV tuner. There is no place to attach your coax TV connector.
To view TV on the unit you would have to either subscribe to cable or satellite TV service or buy yourself an external TV tuner such as listed HERE (I'm not recommending this tuner just showing the kind of device you would need.)
Regards and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
No longer have cable service-will I be able to watch some channels without buying a dtv box?
Hello
The short answer is yes, you can watch over the air DTV programming on your tv without buying another DTV tuner. There is one built in to the tv. You will need some sort of antenna and then
you will have to scan the channels. But the tv is NICE and you will do just fine.
Nov 24, 2010 | LG 42PQ30 42 in. Plasma TV
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
CANNOT TURN OFF CLOSED CAPTION ON 52" JVC TV
Does it use a cable box or are you using the tuner in the TV?
If you're using the tuner in the TV, try unplugging it for 5 minutes and then plug it back in, do a new channel scan and see if the CC goes away. If not, contact JVC to find out how to reset it. If it still does not work, you might need to have your main board replaced.
If you're using an external tuner plugged into a video input port (such as a cable box or satellite box) then the external box is at fault since TVs don't have CC available through their composite or component or svideo or hdmi ports.
Jun 19, 2009 | JVC HD-52G787 52" Projection Television
Broken external Tv tuner for a JVC VM42X795 Plasma TV
You should be able to replace either the F-connector or the entire tuner. I don't have a listing for your specific model, so I can't supply the part number. Check with a local JVC servicer.
Dan
Mar 24, 2009 | Televison & Video
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
JVC PD-42WV74 42 in. Plasma EDTV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
