Question about Dryers
GEW9250plo dryer contolr panel will not light up. Can unplug dryer overnight and the next day can usually get it to come up in diagnostic mode. I am torn between replacing the electronic control boa
Once i get it operational dryer works good on timed dry but does not dry clothes on auto moisture sensing cycles.
    Sergeant:
    Champion:
  • 249 Answers
What color is your unit is. is it biscuit or color pewter or color platinum
Posted on Jan 09, 2013
  • 3 more comments
  • Dennis Duley Jan 09, 2013
    it has a designation of PLO Now i'm not sure if it is pewter or platinum
    color is pewter.
  • Charlie Lapinski Jan 09, 2013
    pewter looks like and and platinum looks like
    pewter is the top one and platinum is the bottom one
    what you need is a new Panel, Console part number 8558751 is for pewter and part number 8558748 is for platinum
docjohn174
  • 943 Answers
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Posted on Sep 15, 2008
SOURCE: Whirlpool Calypso Dryer Electrical Problem
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Posted on Nov 11, 2007
VOTIT
  • 2071 Answers
SOURCE: Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Posted on Aug 25, 2008
  • 1738 Answers
SOURCE: Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Posted on Aug 11, 2009
  • 156 Answers
SOURCE: Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Posted on Jun 03, 2010
Kenmore High Capacity Dryer won't go into diagnostic mode
faulty touch panel key pads are the most likely suspect. Prior to diagnostic you should be able to enter the fault code memory to reference what fault codes are stored in the main board. Pleazer Appliance...
Apr 23, 2014 | Kenmore Dryers
Control panel does not respond on Crosley Dryer Model CDE4205AYJ
Don't you just love electronic controls. On the inside of the dryer is like it always was back in the day with mechanical timers. The same old problem the old ones had is the blower wheel slips and causes overheating or a ball of lint at the base of the filter chute. This eventually blows the FUSE. Their is 2 of them fuses so look close one is usually behind a shield out of sight and may have been overlooked. DIAGRAM
Apr 29, 2013 | Crosley Dryers
Whirlpool Duet gew9250 - Control Lock
The most common reason for this type of complaint would be a failure in the user interface board (UI), if the portion of the board has a short circuit across the lock trails it will demonstrate this symptom.
The fix would be to have the UI replaced. Part number is
8558753 Platinum
8558755 Biscuit
8558756 Pewter
The cost for the part alone is around $160.00 plus labor to install.
I know this is not good news. sorry....
Apr 18, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer won't start after it has been plugged in for a while
DRYER IS DEFECTIVE YOU SHOULDN'T HAVE TO UNPLUG IT IT SHOULD WORK REGARDLESS.
Aug 11, 2009 | Whirlpool GEW9250 Electric Dryer
Controll pannes has dim lights and wont respond to touch
It sounds like a bad timer board . If you unplug overnight you allow discharging the capacitor on control board, that is the reason why it works next day. Check if the power outlet is grounded properly, and test a different outlet. If that does not fix the problem, then test and eventually replace timer board, motor control unit or any other control board present (dryness control if present).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 02, 2009 | Whirlpool GEW9250 Electric Dryer
I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Mar 03, 2009 | Samsung HLT6176S Television
Dryer won't start
Check the door switch, if the switch is bad the dyer thinks the door is open it will not start.
Apr 22, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
