No Power. How do I open it? I want to check the fuse.
  • 3,904 Answers
Screws for removing the cabinet are usually concealed under the rubber feet or info stickers.
Posted on Jan 10, 2013
Fuse to open the luggage lid for 2006 Chevrolet Malibu LS
The power block that includes the fuse and power relay for the power trunk lid are located inside the trunk. After you have opened the trunk lid (using a key), look at the left wall to locate the access flap that is cut into the trunk lining. The fuse block is underneath this flap. The 10 amp mini fuse for the power trunk lid is at location #22 and the mini power relay is at location #36. Check the schematic on the fuse block cover for exact locations.
Feb 10, 2015 | 2006 Chevrolet Malibu
I can't open my trunk or gas door on a 2001 lexus ls 430
At the driver side junction box (DSJB), check the 10A FUEL OPN fuse which is the source of power for the fuel door. The power is applied to the fuel lid opener switch that, when closed, activates the fuel lid opener motor and...POP!
Also at the DSJB, check the 15A ECU-IG fuse which supplies power to BODY ECU 1. At the passenger side junction block, check the 20A P FR DOOR fuse. Next, at engine room relay block 1, check the 10A MPX-B fuse. These three fuses apply to BODY ECU 1 which controls luggage compartment door operation. TSW output from the ECU is applied to the luggage compartment dooe opener switch which, when closed, activates the luggage compartment door opener motor and...POP!
Sep 28, 2012 | 2001 Lexus LS 430
Hp p1005 stopped working
Printer switching on?.Might be power supply failed, replace Power supply board.if you are tech guy..Open left,right & back doors. Check input fuse.. if fuse open replace with same rated fuse, give power, check.. if again fuse is open replace power supply board. if its OK wait few minutes & confirm.. fix it back..
Nov 28, 2011 | HP LASERJET P1005 Printer
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply reading..open the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
I try to turn the tv on but there is no power.
check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Sep 21, 2011 | Sanyo Televison & Video
I need a wiring diagram of the power seat for a 97 chevy venture van
CHECK POWER SEAT FUSE.IF FUSE OKAY.CHECK FOR POWER AT SEAT SWITCH IF YES.HOT WIRE POWER SEAT MOTOR STILL DONT WORK. POWER SEAT MOTOR FAULTY.NO POWER TO SWITCH AND FUSE GOOD CHECK FOR A OPEN OR BROKE WIRE FROM THE FUSE BOX TO THE POWER SEAT SWITCH.
Oct 17, 2010 | Chevrolet Venture Cars & Trucks
Bush lcd27tv006hd no power ,no stndby lights
Open the back cover of the monitor.. check the fuse at the power supply board... If the fuse is open, replace with same value.. at the power supply board check for any blown capacitor and replace it with same value. Check also the power cord for open connection.
Feb 04, 2010 | Bush 5693D 24" TV
Cambridge megaworks 250D won't power up.
Yes, Hi there, as junk996 say, check for the FUSE , and carefully see if burn, or something is bad waired, other than this, if you can RMS the unit is better, or with warranty.
If not, check with s tech guru , for open the panel and check cables, or broken wires. (board inside the sub)
good luck!
Open Sky+
Jun 20, 2009 | Creative Labs MegaWorks THX 250D Computer...
SC542
thanks for the info. care to try again?
Sep 23, 2008 | Ricoh Office Equipment & Supplies
Fuse blown
ok well i would check for a open diode in the main ac to dc power supply then check all resistors that look lick they may be low ohms but high watt check to see if you might have a open pico fuse from primary power supply to the regulator check and see if you have stand by voltage this would be easily checked on the power off oan on button get back to me k
Nov 01, 2007 | RCA F32450 32" TV
k24674
jasbo
jasbo
