I had a problem with my acer veriton M464 motherboard, i had a power outage which shut the computer down, i tried booting it but i see no display on the monitor,i open the system unit and take of the RAM but the motherboard did not beep when i boot the system unit.
  • 3,606 Answers
Hello try to download a user guide here:
http://us.acer.com/ac/en/US/content/drivers
By selecting your pc model.
Try to renew the power supply, or try to boot with one ram stick at the time.
Was it a lightning that cause the problem ??
If so the mainboard could have died.
Good luck
Posted on Jan 09, 2013
antiochpc
  • 1314 Answers
SOURCE: ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Posted on Jul 03, 2008
map9966
  • 2351 Answers
SOURCE: Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Posted on Jul 24, 2008
ginko
  • 19396 Answers
SOURCE: 3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Posted on Aug 16, 2008
SOURCE: 3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Posted on Oct 17, 2008
Daholk
  • 41 Answers
SOURCE: acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Posted on Mar 25, 2009
Veriton m264
in bios try all 0,s
Dec 21, 2013 | Acer Computers & Internet
Can a power outage cause my acer veriton M464 not display?
Have you tried another wall outlet? Hopefully its just tripped fuse.
But yes, A power surge from when the power went off/on could damage the PSU.
Jan 09, 2013 | Computers & Internet
OPEN SIDE PANNEL ON ACER M464
On the rear of the M464, lower right hand side, there is an odd shaped black plastic piece, pull this off and that will reveal a flat metal tab, slide it to the bottom of the machine and hold it there while you pull the side cover off.
Oct 27, 2011 | Acer Veriton M464 (4718235937997) PC...
Need to purchase a motherboard for an Acer Veriton M464
U can purchase motherboard from acer service center.U should check the price at market also.Then take whatever u like.
Jan 08, 2011 | Acer (ACERMOTHERBOARD)
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
Oct 07, 2009 | Acer Computers & Internet
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Acer Veriton M464 - BIOS options disabled by default
no. BIOS is manually enable and disable hardware function in the machine. it prevent detection of uninstalled hardware.
if you enable all of the options, the machine will not be able to power up because some of the hardwares are not installed.
Apr 07, 2009 | Acer Computers & Internet
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
