Question about Dell 1610HD Projector T941202AU Projector
What would cause the over heating warning to come up on my dell 1610hd projector
  • Dell Master
  • 3,904 Answers
Fan not turning on when it gets to a certain temp.
Posted on Jan 10, 2013
How do I connect to computer dell all in one computer
On the back of the computer there should be two types of video outputs, one for HDMI and the other is VGA output. You can use either one just have to get a cable, you can call www.cyberguys.com for the exact cable you need.
Sep 18, 2014 | Dell 1610HD - 1610HD - DLP projector - 3D...
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Projector heating up and bulb shuts down
Jul 08, 2010 | Dell 2300MP Multimedia Projector
I have a Sanyo PLV-Z2000 projector. The screen had a filter warning and we cleaned the filter, but now the screen is just blue and won't omit any image. It worked to reset the filter timer before, but...
the excessive heat and lack of airflow may have caused another problem. can you get into the menu? if you can, try resetting the settings to factory default.
Dec 29, 2009 | Sanyo PLV-Z2000 Projector
Our PJ-TX10 projector is turning itself off
First, to rule out true overheating, clean any dust filters and air-access areas. There might be enough dust on the filter to cause a gradual build-up of heat which could trip one of the temperature sensors in the unit. I clean my projector once a week--There might be a cooling fan going bad--after a while, heat causes the fan motor to start to drag and slows down the air flow. Also, there might be a temp sensor that is shutting down the unit prematurely.--Rick
Sep 06, 2009 | Hitachi PJ-TX10 Multimedia Projector
I get a temp warning on start up and then just shuts down only one fan seems to be working the one next to the lens dose the bottom fan only come on at certain temp. or are both fans supposed to run all...
first blow out any dust out of the projector with canned air. duat holds in heat. if the other fan is supposed to come on at first and doesn't, you would get a fan warning, not a temp warning.
Aug 02, 2009 | ASK Proxima Proxima 5800 SVGA Projector...
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Jul 21, 2008 | Sanyo PLV-Z4 Multimedia Projectors
1200MP DELL Projector flickering problem
You should not try it for yourself, Call a Professional instead.
Jun 26, 2008 | Dell 1200MP DLP Projector
Dell 1610HD Projector T941202AU Projector Logo
96 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
