Question about Roland Ep760 76Key Digital Piano
Power supply rd-100 roland
Diagram
How do I find a new motherboard for this?
Contact Roland customer service. You might also want to try Roland Canada.
Aug 11, 2015 | Roland Rd-300nx Digital Pianos
300GX. How do I reinitialize?
The instructions are on page 77 of the manual, which is located here-
http://lib.roland.co.jp/support/en/manuals/res/1810808/RD-300GX_e2.pdf
Aug 01, 2015 | Roland Music
I need the schematics for the Roland CK-60 amp or the wire diagram.
This MIGHT be close to your unit... it is for the KC-100... they often use the same circuitry.
http://elektrotanya.com/roland_kc-100.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. There may be slight variations but these amps are simple enough to troubleshoot. USE the old trick of putting an incandescent lamp of say 100 watts in series with the power input to act as resetable fuse and save fuses when powering up after a repair.
Apr 29, 2011 | Roland KC60 (40W 10 3Ch Keyboard Amp)
My Roland Rd-500 has no sound....the factory demo
You either did not get the ribbon cable seated OR got it upside down.
If this cable is the flat ribbon with exposed solder plated points of contact, OFTEN those connectors have a latch to release by GENTLY moving tabs on eaither side in the direction of pulling the cable out. This lock MUST be moved out slightly to allow the cable to seat properly. The solder plated contacts will be FULLY into the connector when seated properly.
These cables ALSO can be inserted backwards and NO connection will be made.
Feb 14, 2010 | Roland Juno-D
Where do I get spare parts for my Roland rd 300s. Thanks
It depends what parts. Mechanical things and special chiops you need to contact Roland support parts dept. Go to Roland site and go to support.
For common electronic parts, go to DigiKey.com or Mouser,com.
Feb 11, 2010 | Music
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Transpose feature
Here is the ROLAND website. I am afraid that you have to give you e-mail to go further.
http://backstage.rolandus.com/login.php
Dec 17, 2008 | Roland Music
Roland Ep760 76Key Digital Piano Logo
50 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
