Question about LG LFC22740 Bottom Freezer French Door Refrigerator
Lg lfc22740st refrigerator keeps going out and i have to reset power
The thing has stopped working 5 times in the last couple of weeks, just the fridge, the freezer still works. I have to unplug the cord and then plug it back in and it starts working
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
huuum
  • 750 Answers
SOURCE: My LG fridge freezer has
Hello finokane,
welcome to fixya.
Happy to be of service
You said, your LG fridge freezer has man times stopped working for no reason. Unfortunately it has happened many times when you have been on holiday. Sometimes just the fridge goes off and sometimes just the freezer, but usually both go off. If you switch off the appliance at the plug and switch it back on, everything starts to work again. You are thinking of getting rid of it as you have lost so many freezers full of food.
How old is the freezer.
My advice is get a new freezer.
It will pay for itself in only a few years!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a solved rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
SOURCE: LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Posted on Dec 09, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Posted on Feb 09, 2009
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
Frige just stopped. Has power at outlet. Only a couple years old, if that. Is there a reset switch? Thanks
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Refrigerators
My refrigerator is over 5 years old. the refrigerator is making a rumbling noise and a beeping noise. i have switched it off hoping that it would reset itself.
Refrigerator
heatman101
Jan 16, 2011 | LG Refrigerators
I can send text messages but can't receive them. How do I reset my enV3 phone?
That happens to me. The first couple times I just ignored it and after about a week, i would all of a sudden receive the week's worth of texts. Last time it happened, I called the warranty replacement number (18664065154) and the representative had to reset my phone somehow and that fixed it. (He had me try several things before that, none of which worked, and they would probably make you do it also.) But now, it's been about two weeks and my phone is doing it again. So....get used to it.
Oct 12, 2010 | LG enV3 VX9200 Cell Phone
Hey our refrigerator has stopped working completely. There is no power being accepted by the machine and it has completelly shut down and will not start up again. What should we do? It is an LG LSC27910TT
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 10, 2010 | LG LSC27910TT (265 cu ft) Side by Side...
My LG LFC25760 has stopped working. We have cleaned out the under and backside of the fridge. Unplugged and plugged it back in. After the first time it worked for a couple of days and now it has stopped...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 31, 2010 | LG LFC25760 French Door Refrigerator
I have a Honeywell T8601D thomastat. It has been in service for 5 years and operated well. In the last month, it has gone "dark" (stopped working) 3 times. The first time it stopped working for a couple...
If you have a float switch on your drain line and the drain is backing up this will cut power to the tstat. Drain slowly drains, float switch resets, power comes back to tstat. That's my educated guess. But, is there batteries in the tstat?
Jun 25, 2017 | Honeywell Electronic Programmable...
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Lg refrigerator LFC22740ST loud humming noise no
You have a bad fan motor ... replace motor.
Nov 11, 2009 | LG Refrigerators
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
LG LFC22740 Bottom Freezer French Door Refrigerator Logo
99 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
