Question about Electronics - Others
Cant figure out tomahawk new genny ignition to start from inside
I managed to solder to the back (using a multi meter) so it will tun on then press button and starts from inside, but it won turn off and remotes dont weork long, i hah to have key on to do it, but i cant figure out how to start it from the house and stop it too. any one can help i can send photos, please krishardy2004 (at) gmail, if anyone can help with a diagram or need pics to draw me one PLEASE.
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
Posted on Jun 26, 2008
SOURCE: Kenwood DDX7015 password reset please help
yo u need a reciet of purches and u can send it in. do wat i did go to a sound shop ask one of the people there to make u one and slip him a twenty beleave me its worth it i got the same screen as u and its bad ***. try it
Posted on Apr 13, 2010
  • 42 Answers
SOURCE: 2000 Buick regal, ignition /
It sounds like the anti theft lock is engaged. There should be 2 white wires hooked to the ignition. they are very easy to break in the halo surrounding the key. They measure resistance in the key itself. there should also be a plastic piece just behind the lock cylinder with a silver rod coming out of the bottom of it. That is the anti theft. If the wires are broke in the halo, it will not allow the rod to punch up and the key to turn. Take a ohm meter and test both wires. if with the key in you get no resistance measured, your halo is broken. You have to replace the lock cylinder and key. Then take it to the dealer to have the computer reset to recognize the new resistance setting.
Posted on Sep 11, 2010
Testimonial: "Perfect answer to do the repair the right way, I am a handy man looking for a short cut and low cost to no cost solution, to help a poor elderly woman"
  • 1098 Answers
SOURCE: went to hospital parked car came out key fob not
Im not sure there is any easy fix for this so I will just give a little advice.
Can you give me the make and model of the car? and is the alarm and immobilizer a standard factory one? Will do my best to help you once I know the make and model, and the year please.
Posted on Nov 07, 2010
  • 2620 Answers
SOURCE: My 2005 Hyundai Tucson won't start it has a new battery new plugs and new filter
Well Carol do you if the sparkplugs are getting fire to them or are you getting spark?
Posted on Jan 13, 2012
How to change language in mitsubishi multi communication system
1. Press and hold the multi-information meter switch for about 2 seconds or more to switch from the setting mode screen to the menu screen.
Refer to “Changing the function settings (when the ignition switch is “ON”)”.
2. Lightly press the multi-information meter switch to select (language cooperative control).
3. Press and hold the multi-information meter switch to switch in sequence from
3. Press and hold the multi-information meter switch to switch in sequence from A or 1 (language cooperation enabled) ? M, 2 or P (language cooperation disabled) ? A or 1 (language cooperation enabled).
Hope you get your problem fixed :)
May 19, 2016 | 2006 Mitsubishi Outlander
No spark after rebuild
need a bit more detail did you remove the electrics.
Usual thing is to start with a full charges battery.
Take the plugs out to make cranking easier and check plugs.
Have plugs been change with a know set of good plugs that spark?
Obviously this will have engine management system with multi plugs.
Use the work shop manual with a multi meter to check each junction from the battery through the ignition circuit.
Do all the other electrics work?
Dec 06, 2013 | 2002 Yamaha YZF-R1
Tomahawk uh-23
I found two tomahawk uh 23 used helicopter on eBay for $11.99 for parts.
Nov 14, 2012 | Jumbo RC JUMBO HELICOPTER
My md7030 is new, just out of the box. the instructions for set up say to adjust all the switches then press the red button and the meter should 0 zero out. the meter is on 3 of the non ferrous side...
you need to use the tunning to adjust for any interference.. place it flat on a surface that is free of any interference.. then turn the tunning knob until u hear it go high pitch.. push the reset button until it centers takes some practice..use different kinds of metal until u can tune it on the sound .. the higher the pitch the better the chance its worth digging for...good luck\
Nov 02, 2010 | Famous Trails Discriminator Ii Metal...
I have a 93 gsx600f katana I replaced my battery, seliniod, coils, cables, kill switch, cdi box, and kick stand switch. still wont start i press the start switch and nothing. i put a screwdriver on my...
some models need the clutch in (even in neutral) to start, Check if there is a small micro switch under the clutch and check it works with a multi meter
Jun 11, 2010 | 1993 Suzuki GSX 600 F (Katana)
My Y2K driver window went down, and won't go back up.
Hello. The best way to determine if the switch is good is use a digital multi-meter,( $12.00 at wal-mart). Then remove the inside door panel, and plug the switch back in and probe the wires going into the motor while you operate the switch with the ignition key in the ON position. If it shows 12 volts as you press the switch, ( both up and down ), then you most likely have a bad motor.
Mar 20, 2010 | 2000 Chevrolet Impala
Cant set the clock
1 Use MULTI-CONTROL to select
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
As you select segments of the clock display,
the selected segment blinks.4 Turn MULTI-CONTROL to put a clock
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Mar 26, 2009 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Electronics - Others Logo
390 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
