Question about PSC QuickScan 6000 Plus Handheld Barcode Scanner
Continuous bleep when connecting scanner to the PC via the PS/2 keyboard port the scanner emits a continuous bleep & doesn't scan. This happens with the keyboard attached or left unattached.
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
I just got an LS4006i scanner with a ps2 connection. When I plug it in, it beeps 3 times. When I scan a bar code, it beeps once and the lite turns green, a slight pause the 3 beeps. nothing comes up on the...
The cable has to have a PS/2 keyboard connected to it and you must be connected to the keyboard port. Unfortunately this scanner did not support "Notebook" mode where you could make it think it was connected to a laptop and leave the keyboard connection open. The other thing to check is that the "IBM PC/AT" barcode is scanned from Adobe page 55 of 182 of the LS400Xi Product Reference Guide.
Nov 20, 2009 | Symbol LS4006 (SYMLS4006I10014) Handheld
DON'T KNOW HOW TO USE
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
Feb 14, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
Computers & Internet Logo
20 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
pkwc
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
