Question about Miniclip SA 8 Ball Quick Fire Pool
8 ball bool - Miniclip SA 8 Ball Quick Fire Pool
Tip
See file path(s) On OSX 10.5
GO to terminal and type: defaults write com.apple.finder _FXShowPosixPathInTitle -bool YES
This shows the file path of the folder on windows instead of the name.
To revert type in terminal: defaults write com.apple.finder _FXShowPosixPathInTitle -bool NO
on Dec 21, 2009 | Computers & Internet
Download kindle bools to my MacBook Pro laptop?
http://www.amazon.com/gp/kindle/mac/download
that will download the program you need. from there you should be able to download the books from the amazon store.
Apr 10, 2010 | Apple MacBook Pro PC Notebook
How do i time a 00'toyota tundra 4.7 motor timing belt broke and then broke cam cover.
BROKE THE CAM COVER??, SOME ENGINES,have interferance heads,this means,you MUST!!,GET A TIMING BELT BOOL FROM YOUR LOCAL PARTS STORE.
Apr 04, 2010 | 2000 Toyota Tundra
My bool will not lock
try sprayingf a good lubricant into the locking mechanism in the boot lid it mave have just dried out and try turning the key in it to work it loose after you spray it
Jan 09, 2010 | 2003 Volkswagen Passat
Can you please give a simple program about defined data types?
http://www.cplusplus.com/doc/tutorial/other_data_types/
Or are you talking about the predefined data types like bool,int,float etC?
Jun 25, 2009 | Computers & Internet
Program for calculator using vc++
hi, here the code...
class is used for items(item.h) . In this class are stored the two number into property and the result:
property double nr1;
property double nr2;
The operations like :asin,cos,power,pi,plu,divide,sqrt etc. are edited into inherited class from items:
#pragma once
#include "Items.h"
using namespace System;
public ref class asinus : public Items
public:
asinus(void)
double^ asin(double a)
return Math::Asin(a);
In the base class 6 boolean variable is used for the precedent operation:
bool plus;
bool minus;
bool produs;
bool divide;
bool sin;
bool prec;
For button equal:
private: System::Void btnegal_Click(System::Object^ sender, System::EventArgs^ e)
prec = false;
if(plus == true)
this->txtRes->Text = Convert::ToString(p.aduna(i.nr1,i.nr2));
else if(minus == true)
this->txtRes->Text = Convert::ToString(m.scadere(i.nr1,i.nr2));
else if(produs == true)
this->txtRes->Text = Convert::ToString(pr.inmultire(i.nr1,i.nr2));
else if(divide == true)
this->txtRes->Text = Convert::ToString(d.impartire(i.nr1,i.nr2));
there is a function for operaton click:
private: System::Void Operation_Click(System::Object^ sender, System::EventArgs^ e) { if(prec == false) { i.nr1 = Convert::ToDouble(this->txtRes->Text); } if(prec == true) { i.nr2 = Convert::ToDouble(this->txtRes->Text); } }
Apr 10, 2009 | Microsoft Computers & Internet
Miniclip SA 8 Ball Quick Fire Pool Logo
Top Miniclip SA Facebook Apps Experts
ray gallant
David Payne
David Payne
masud
masud
Are you a Miniclip SA Facebook App Expert? Answer questions, earn points and help others
