Question about Technics SA-DX1040 Receiver
Sa515-l no sound in protected mode now permanently is it worth fixing
    Genius:
  • Technics Master
  • 1,054 Answers
Check the bottom of the receiver. there should be an access panel under the amp ic section. Look at the connections on the amp ic's and voltage regulators that are next to them. If you see any round rings or loose looking connections, it could just need to be resoldered. This is pretty common on these receivers.
Posted on Jan 09, 2013
Amp Protection Mode
TRY DISCONNECTING IT FROM THE BATTERY FOR ABOUT AN HOUR. SEE IF THAT HELPS.
Nov 17, 2013 | Car Audio & Video
Tv does'nt Pwr up
will need to be taken apart to figure problem. check fuses and for any burned component. possibly if no high voltage.. not worth fixing.
Oct 05, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Tip
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at Joshadk@embarqmail.com and i will help you the best i can
on May 16, 2010 | Pioneer VSX-816-K/S Receiver
Dav-dz30
Sounds like unit is in protect mode. This is usually caused by a problem in the amplifier section. Only way to fix is to replace the main board - hope it's under warranty, otherwise it's probably not worth fixing
Jan 04, 2013 | Sony DAV-DX375 System
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
Jul 15, 2010 | Autotek MM125.2 Car Amp
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
What's a good used price for this 5230 + speakers and is it worth getting used. $65 is that good or too high.
Hi. that's a really good price but, make sure it is not in protect mode and it actually works. Plug it up and test all channels for complete sound production.
If it passes the sound test and is not in protect mode, its a steal and i would purchase it.
Please rate and god bless:)
Apr 23, 2009 | Yamaha HTR-5230 Receiver
Technics SA-DX1040 Receiver Logo
64 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
