Question about HP Color LaserJet 2600n Printer
Hp 2600n printer
My printer shows that the black toner is empty. I purchased a factory hp toner and placed it into the printer. It still shows the toner needs to be replaced. I have put another new toner in the printer and it still shows the black toner is empty.
I have uplugged the power an did not do anything.
please help for God sake.
  • 14 more comments
  • faddykay Jan 23, 2009
    did as suggested by Wiz but the printer is still showing that the black toner is empty. I purchased a factory hp toner and placed it into the printer. It still shows the toner needs to be replaced. I have put another new toner in the printer and it still shows the black toner is empty.
    Hi Bestdarngood:
    my printer is still not working the message is still coming up. Hope U and other tech guru can help.
    Faddykay
    please where is the chip sensor in the printer. I tried and cleaned the toner metal plates . Please explain firther.
    Thankx
    Faddykay
    Where is the utility for the printer
    Tahnkx
    no show. I am still getting the message
    It is only the black ink catridge that is showing me this error.
    the ink cartrige is new and is working fine
    I have tried this option earlier and I am still having the replace supply (black ink) problem.
    no show
    i have tried this option with no show.
    I hope someone out there can help. I have tired all suggestions given so far with no result.
    i did all these ealier. still having the error message.
    toner si okay I think the problem is with the printer itself.
    I did this already
    I did uninstall and reinstalled the software and no show
    No show
    Brigadier General:
  • 6,966 Answers
Hi and welcome to Fixya,
It would seem that most of possible solutions have been posted. To my knowledge, a new toner cartridge would have a shipping tape and a strip of shipping lock; both of which must be removed prior to installation. Thereafter ensure that the small electronic board is attached firmly to the cartridge. You may also want to inspect the receptacle where the small electronic board of the cartridge slips into. There should be no obstruction, bits of paper or tape. The small electronic board and the matching slot that it fits into would have matching gold pins that contacts each other when installed properly. Clean both. You can start with a can of compressed air but pls use sparingly and try to regulate to a low pressure. On the gold pins you can use a pencil eraser to rub out any tarnishing or light corrosion. If the slot would not allow this, a flattened cotton bud dipped in alcohol would also serve the purpose. Pls allow to air dry.
Should the above be not sufficient, it may be necessary to reinitialize the NVRAM:
  • Turn off the printer.
  • Press and hold the SELECT and CANCEL JOB buttons simultaneously.
  • Turn on the printer.
  • When you see the message Permanent storage init displays, release the SELECT and
  • CANCEL JOB buttons.
  • When the NVRAM init is complete, the printer will return to the Ready state.
If still a no go, put the printer into STBY mode and press the engine test print switch which is at the back of the printer. Press once momentarily. Pls post back result(s).
Good luck and thank you for using FixYa.
Posted on Jan 25, 2009
  • HP Master
  • 19,396 Answers
That often happpens because toner dust had spread inside the printer, and toner sensor is dirty.
Follow suggestions below to clean the printer:
Clean your laser printer safely
Posted on Jan 23, 2009
  • 15,935 Answers
Install black cartridge Error message Install black cartridge alternates with Hp 2600n printer - c00381084.jpg (gas gauge) with a ? under the missing black gas gauge. Description Black print cartridge is not installed (identified by "?" character) or the out threshold has been reached. The supplies gauge will display the consumption levels of print cartridges. Action The black print cartridge must be replaced before printing can continue. CLICK HERE for a complete listing of your printer's error messages and the corrective action. Can you give the EXACT error message you are getting?
    Genius:
  • 1,199 Answers
You may want to try reinstalling the software for the printer restart pc and try again!
  • 11,896 Answers
Of course you have to remember that the drum is part of the tonercartridge and after the second refill you will probably need to replaceit. Looking around on ebay itseems a 4 color toner set with chips cost around $94 (black only around$45) if you want to go that route. You can also get a tool that willmelt a 3/4" hole into the toner cartridge for easy refill
making holes in the cartridge's 'waste toner' bin and removing thatexcess toner, then plugging the holes, making another hole to fill the'fresh toner' bin, and finally replacing the 'circuit board chip that is connected to the toner
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jan 23, 2009
    This is what the chip looks like that I think needs to be replaced.
  • Nate Stansfield
    PERFORMING RESET:
    1. Use the
      (LEFT ARROW) or the
      (RIGHT ARROW) button to select Service,
      and then press
      (SELECT).
    2. Use the
      (LEFT ARROW) or the
      (RIGHT ARROW) button to select Restore defaults, and then
      press
      (SELECT).
    The device automatically restarts
    If you'd like here is the hp support site just for your printer with error codes and solutions as well as free online live help. (copy and paste in your browser)
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    your need another toner CROM communication reset chip
    President:
  • 2,110 Answers
HP Color LaserJet 2600n Printer - Changing Print Cartridges Changing print cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). To change the print cartridge
  1. Open the front door. Hp 2600n printer - c00314362.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  2. Remove the used print cartridge from the printer.
  3. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00314364.gif
  4. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from side to side. CAUTION: Do not touch the shutter or the surface of the roller. c00314365.gif
  5. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local reHp 2600n printer - c00314366.gifimg src="http://i.fixya.net/uploads/images/c00314366.gif" alt="c00314366.gif" class="h_mi" />
  6. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridHp 2600n printer - c00314367.gifs firmly seated. c00314367.gif Firmly close the front door. c00314368.gif After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  7. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  8. If a non-HP print cartridge is being used, check the printer control panel for further instructions.
For additional help, go to http://www.hp.com/support/clj2600n .
    Sergeant:
    Champion:
  • 435 Answers
Hi, Switch off the printer. Disconnect the toner. Switch on the printer and see if the error still comes up.
Now, shutdown the computer. Switch off the printer. Clean the place where the toner is loaded.
Load the toner and switch on printer and computer.
If the error still comes up, try re-installing the driver.
  • 837 Answers
  • 8,197 Answers
This is not covered in any manual so print this out:
On the front of the printer are 2 arrow buttons and a "check" button.
1. press the "check" button (the LCD will read "Main Menu Reports")
2. press the right arrow (the LCD will read "Main Menu System Setup")
3. press the "check" button (the LCD will read "System Setup Language")
4. press the right button twice (the LCD will read "System Setup Print Quality")
5. press the "check" button (the LCD will read "Print Quality calibrate color")
6. press the right arrow 3 times (the LCD will read "Print Quality Replace Supplies")
7. press the "check" button (the LCD will read "Replace Supplies Override Out" or "Replace Supplies Stop at Out")
8. press the right until you see the LCD screen say "override Out"
9. press the "check" button to accept whichever option you want. The default is that the printer will stop when IT detects that the cartridge is empty, not when the cartridge is actually empty. If you accept the "Override Out" option, the printer will NOT shut down when IT thinks the toner is out, and you can decide for yourself by looking at the printed page when the toner has run out.
Hope it works for you
  • Jyackle5
    Jyackle5 Jan 23, 2009
    Do you need to tell the printer it has a new toner cart. Check your printer control panel. There is a setting 'new toner yes/no' something like that. I am not in the office right now, so I can't tell you exactly.
  • Jyackle5
    Try this.
    Cold-reset, which power-cycles the engine with a special button press, is not supported for this printer. Instead, use the feature "Restore defaults" located in the Service menu to reset default settings.
    Restoring the factory-set defaults
    Restoring the factory-set defaults returns all of the settings to the factory defaults; however, it will not affect the embedded network solution settings.
    Restore the factory-set defaults
    1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
    2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then press (SELECT).
    The device automatically restarts.
    Genius:
  • 2,035 Answers
Try to see if it still is the bongo pumps acting up (the white pads underneath the cartridges) would be to open the front cartridge cover and the printhead cover, remove all the ink cartridges and then power up the printer. Take note of the bongo pumps and if they move up and down properly. If not, that may be the cause of an out of ink message
Good luck...
  • Anand Kumar
    Anand Kumar Jan 23, 2009
    1. Open the front cover of printer and remove the toner cartridge exhibiting error.
    2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
    3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
    4. Inspect the e-label reader to ensure
      the gold contact points are not damaged or bent. Also inspect the black
      plastic on e-label reader to ensure it is not bent or broken.
    5. Reinstall the print cartridge.
    6. Power cycle the device.
  • 177 Answers
Hello and welcome to FixYa!,
Sorry to say but it Sounds like the Sensor on the Printer that Detects the Black ink is Dead!
The Only Way is to Replace the Printer!
This Should Work, --P3NGYJ03
    President:
  • 2,559 Answers
Did you by chance forget to remove the protective tape from the new ink cartridge?(no offense,but this happens)
If not,take a Q-tip with a little alcohol and clean the area inside the printer where the printer head makes contact.
  • 700 Answers
Take and go to the utility for the printer and clean the head. then oit shoiuld be able to see the new cartrige.
Posted on Jan 21, 2009
    Scholar:
  • 160 Answers
Hp 2600 cartridges have chips on it which gets detected by printer chip sensor.if the cartridge is new then the problem is with the chip sensor.clean the chip sensor and check initially.
  • 3,037 Answers
Hi faddykay
Make sure you remove any labels over the metal contacts, clean the contacts on the cartridge and the printer and if that doesn't help, then unplug the printer and uninstall it and then reinstall it and plug it back in and it should work. Let me know if that still doesn't work, it should but might not and then we have to do something else
bestdarngood
    Sergeant:
  • 378 Answers
The sensor which detects the toner in the printer is got moved from its positiuon.just needs to be adjusted.just open the door remove all the cartridges from the printer.then off the printer.then on the printer and reinsert the toner.
  • machine83 Jan 23, 2009
    printer in error mode needs a technician at your place to reset the printer by removing and reinserting the round chip battery on the board. this will clear the error.
  • 4,472 Answers
Did you use the last toner beyond empty. This can cause a problem. Once I have more information I can assist you further.
Thank you,
Lee
  • Lee A.
    Lee A. Jan 21, 2009
    Also have you tried the cartridge out override feature to see if it will worth then.
    Configuration
    Cartridge Out Override can only be enabled from the printer's control panel menu.
    1. From the main menu, press (RIGHT ARROW) to System setup and press Check Mark button (SELECT).
    2. Press (RIGHT ARROW) to Print quality and press the Check Mark button (SELECT).
    3. Press (RIGHT ARROW) to Replace supplies and press Check Mark button (SELECT).
    4. Press (RIGHT ARROW) to Override out and press Check Mark button (SELECT).
    5. Press (Check Mark button SELECT).
    If Stop at out is selected, the printer will stop printing when a
    cartridge reaches the recommended replacement point. If Override out is
    selected, the printer will continue printing when a cartridge reaches
    the recommended replacement point. The factory default setting is Stop
    at out.
    if it works then most likely it you just need to reset the counter.
    Thanks,
    lee
  • Lee A.
    Lee A. Jan 21, 2009
    That hopefully should get you going again, Also please take a moment to accept and rate my solution and I will be more then happy to assist you further if need be.
    Thanks,
    Lee
When i print toner status black color is faded as well as yellow and cyan, magenta showing white color, can you please give the best solution for this. by the way i am using hp 2600n. thank you very much.
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
GoodLuck!
Dont forget to appreciate the solutions if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Aug 26, 2008 | HP Color LaserJet 2600n Printer
HP 2600n printer showing empty black toner
maybe u have to reset the printers counter..
Jul 22, 2008 | HP Color LaserJet 2600n Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
Seeker5211
Seeker5211
