Question about Brother IntelliFAX 5750e Laser Fax
The user is getting a clear Paper jam message on the menu display of a Brother intellifax 5750e. I checked all areas and there is no paper jam to the naked eye. I pulled the toner and replace the unit in which the toner sits in I believe it in the dr-400? Not certain. Is there a place in the menu that I can reset or clear the message "Clear Paper Jam"? thank you wk Number tonight is (718) 742-3186
    Champion:
  • 320 Answers
NO THE PAPER NEEDS TO COME, I BELEIVE THE PAPER MIGHT BE INSIDE THE FUSER SECTION AND YOU WILL HAVE TO TAKE OUT OF THE MACHINE AND OPEN IT, GOOD LUCK
Posted on Jan 21, 2009
My Brother Intellifax 5750e has paper jam issue. The paper jam sign will not go away. I took out the paper that was jammed. Still problem.
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
Jul 28, 2011 | Brother IntelliFAX 5750e Laser Fax
Getting paper jam message but there is no paper jammed will not reset itself
Generally, when a paper jam message is displayed, there is in fact some sort of debris, dirt, or paper pieces blocking the paper jam sensor. My suggestion, take a thick piece of card stock and manually feed it through the paper path; this should hopefully clear any debris that is blocking the jam sensor in that area. Also, try spraying some canned air into the paper path, as if there is dust blocking the sensor, it will be more likely to be removed with air than card stock.
-David.
Nov 03, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
My brother intellifax 5750 has a paper jam and it wont clear.
make sure no paper is in unit then turn off and unplug for 5 minutes then plug back in and turn on
Mar 06, 2009 | Brother IntelliFAX 5750e Laser Fax
Brother® IntelliFAX® 5750e Laser Plain-Paper Fax
THERE ARE TWO REPORTS:-
1-transmission verification report.
2-fax activity report.
for(1)press menu-2-4-1
for(2)press menu-2-4-2.
Mar 20, 2008 | Brother IntelliFAX 5750e Laser Fax
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
How do I get it to print docs in memory?
Does the fax machine produce a copy? If there is a paper jam/toner error, this needs to be sorted first. What is on the display?
Aug 20, 2007 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
171 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
