Question about Samsung SyncMaster 460PXN LCD Monitor
Check cooling system - Samsung SyncMaster 460PXN LCD Monitor
Changed a radiator today, drained system. Hot water will not heat now. Heating and radiators are working ok
Helen, if it is the radiator in your car that was changed, you may have air in the cooling system that needs bled out. May also be a failing water pump, thermostat,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Bleed Cooling System EricTheCarGuy
Bleeding Air In Cooling System
How to Bleed Air From Your Cooling System DoItYourself com
May 02, 2016 | Cars & Trucks
I've eplaced the thermostat on my 2014 HD Ultra Limited. Apparently I was supposed to bleed the cooling system after I refilled it, but I can't find any how-to's on accomplishing that. Any tips?
Remove rad cap while cold start and run engine making sure to keep it full also check for air bleeds along the system usually near tstat or on top most cooling system component
Mar 16, 2016 | Cars & Trucks
Is there 2 pumps on cooling system
No there is not two pumps on a cooling system. If your car is overheating then it can be many problems. Take it to a professional where they can further diagnose it.
Jan 04, 2015 | 2000 Chevrolet Venture
Overheating,
First check the level of cooling .After check cooling system when engine work open the radiator and check for cooling fluid moving or not when you throttle .Or may be have air in the cooling system and make air pillow.
Dec 15, 2014 | 2011 Honda CBR125R
I just put a brand new radiator and radiator cap in my car and its still over heating and now its misfiring what could be causing this?
Did you bleed the cooling system? and check operation of the thermostat, which should have been done after fitting radiator before finishing by putting on radiator cap.
If not remove radiator cap when cold get vehicle warm and check thermostat operation, while bleeding any air pockets in cooling system and if no flow and bubbles or it starts to boil (shooting water) out of radiator the thermostat could be jammed or head gasket blown.
Sounds like it could be a blown head gasket. Get it hot again and miss firing, remove and inspect all spark plugs you may find a very clean spark plug indicating water entry into that cylinder or even water/coolant droplets in spark plug. You can also hold paper over spark plug holes and give the engine a quick crank over to see if any water comes out of cylinder while cooling system is still under pressure, or use radiator pressure tester to pressurize cooling system, wait 5-10 minutes and then crank over checking for water/coolant in cylinders. Another tool to check for blown head gaskets that cause overheating is a TK Head check, which sniffs the cooling system for evidence of exhaust fumes in cooling system.
Jul 21, 2011 | 1992 Toyota Celica
Code P0A93 for toyota PRIUS WHAT IS THE PROBLEM ? Check Engine light and ! and VSC Warning lights I looked up code P0A93 equals StandaRD DTC'S (ISO 15031-6/SAE J2012) WHAT THIS MEAN?
P0A93 is an inverter cooling problem. The inverter is cooled by a dedicated cooling system, which consists of an electric water pump, cooling fan, and radiator. This cooling system is independent of the engine cooling system.The mechanic should check if there is sufficient amount of coolant for the inverter, check if the coolant hose is not bent or clogged, if the water pump / cooling fan motor connections are ok, and of course if both of the cooling fan motors are OK
Sep 20, 2010 | 2004 Toyota Prius
Hello Ive got cooling fault on my galaxy 3000 can u help
try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Sep 04, 2010 | MGE UPS Galaxy 3000 UPS System
How to change a radiator
1988–91 Models
  1. Disconnect the negative battery cable.
  2. Properly drain the cooling system into a suitable container.
  3. Disconnect the fan motor and motor connector.
  4. Disconnect the upper and lower radiator hoses.
  5. Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
  6. Disconnect the coolant reservoir overflow hose.
  7. Remove the radiator attaching bolts and brackets.
  8. Remove the radiator with the cooling fan attached.
  9. Remove the cooling fan and shroud from the radiator. NOTE: Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary. To install:
  10. Attach the cooling fan and shroud to the radiator and install the assembly.
  11. Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
  12. Connect the coolant reservoir overflow hose.
  13. Connect the automatic transaxle cooling lines to the radiator, if equipped.
  14. Connect the upper and lower radiator hoses.
  15. Connect the fan motor and thermo-switch wire connector.
  16. Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
  17. Reconnect the negative battery cable. Fig. 7: Cooling system components — 1988–91 engines 86833085.gif
1992–95 Models
  17. Reconnect the negative battery cable. Fig. 8: Cooling system components — 1992–95 engines 86833086.gif
Aug 27, 2010 | 1991 Honda Civic
Cooling fan on radiator do not work sending unit on block checks ok with oms meter relay in fuse box ok now what
Change the thermostat and bleed the ir from the cooling system,then ,if the cooling fans do not come on,check the relay module under the cooling fans on drivers side,they are bad to go out,but if there is air in the cooling system,the cooling fans will not come on.
May 31, 2010 | 1998 Dodge Caravan
Auto transmission taking lots of fluid to fill
did you recently empty the tranni? like fluid or filter change? If not, there is a leak. I've seen the radiator go bad and tranni fluid gets forced into the cooling system. Check cooling system for reddish oily substance. If there is, replace radiator and refill tranni and cooling systems. may be a good idea to do cooling system flush.
Dec 11, 2008 | 1997 Chevrolet Astro
Samsung SyncMaster 460PXN LCD Monitor Logo
Henry  Thomas
Henry Thomas
