Question about Konka Televison & Video
Ic regulator tv konka k2166cz - Konka Televison & Video
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: solution
You have a bad vertical output IC or a bad capacitor(s) in the vertical driver or output circuits. Not a job for the user to do unless you have the proper tools as well as a service manual. Good Luck
Posted on Mar 28, 2007
  • 4 Answers
SOURCE: Dead KONKA 21 inch TV
try Check first all the output voltage in the secondary of the chopper transformer if regular voltage acquire. check secondary switching circuit feedback towards the opto isolator and syscon.
Assuming that HOT is OK.
Posted on May 07, 2008
jerryg50
  • 1667 Answers
SOURCE: regulator ic of sony tv kv-g21c1
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
Posted on Sep 01, 2008
I have a Konka CTV K2166CZ. It's powering ON but no picture, no OSD only equally spaced retrace lines. 180volts vcc to blue, red & green transistors collector drops to 28volts.
Check the base voltages of the video output transistors. If it is found high [ more than 3V or so]; the main system control chroma jungle IC is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 03, 2015 | Televison & Video
Ceting tv konka model u21ek602a1
What is the problem you faces with this TV? Provide more details please. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Konka Televison & Video
My konka television picture has shrunk to a small section of the tv please help
Check the power regulator section circuit. Check all the capacitors there. Repalce them if found faulty.
May 11, 2012 | Konka K1369U 13" TV
Service mode tv konka K1418C
replece memori ic i need service konka tv service mode
Aug 28, 2010 | Konka K1398U 13" TV
KonKa flat screen: during viewing the screen goes blank but the audio remains on.
You may have a bad ground on the horizontal transformer. This is a common occurence on any brand. Somewhere there is an open solder ground and they may be almost anywhere. Look at the soldering under the flybackout, the soldering on the vertical IC and the soldering on the horizontal output transistor. Pay attention to any and all ICs soldered to a heat sink or cooling fins. These are high heat areas and must be inspected very closely! And check out those high power resistor grounds. I think just a good soldering will restore your TV. Thanks for asking!
Aug 07, 2010 | Konka Televison & Video
Konka television model k2927ez
Good day.
Try to check for the Regulator IC and the components attached on it. There might be some busted parts on it.
Regards,
chris
Aug 18, 2008 | Televison & Video
Nov 01, 2007 | Televison & Video
Solution
Mar 28, 2007 | Konka K2386U 23" TV
Televison & Video Logo
49 people viewed this question
Top Konka Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
