I have valor radiant heat fireplace purchased new and installed in 2008. Recently the temerature has fluctuated as much as four degrees F and the unit shuts itself off instead of maintaining a constant temperature. When the room cools 2 dgrees below the setting on the remote the sensor turns the flame up to high, heats the room 2 degrees above the setting then shuts off. It won't automatically adjust to a low flame to keep a consistent temperature. The receiver is a G30-ZRRTT. It does not have a reset button. Changing the batteries hasn't had any affect.
SOURCE: My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Posted on Nov 20, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
SOURCE: Patton PRH11 Buzzer Sounds on HIGH after 2 minutes
There is a round sensor under the heating elements which sets off the alarm when it thinks it is overheating on the PRH11. Unfortunately, a dirty sensor will fool it into reacting like it is overheated. I cleaned the sensor which was dark and revealed it to be a lighter goldish maybe brass in its original color. If your sensor is dark, it will continue to trip the alarm for overheating and will need to be replaced. If you were lucky like I was and can clean it, the problem should be resolved and it will operate like normal until it gets dirty again. This procedure lasted for 3 days and I had to clean it again. I believe I left the dirt on too long and now my sensor has tarnished plus I live in a rural area with significant dust requiring this recleaning every few days. I only used a damp paper towel with water to clean. Cleaning may work better with alcohol or a tarnish removal solution.
Posted on Dec 11, 2009
vetteman3002
  • 2299 Answers
SOURCE: Honeywell Receiver/Valve Model No. RV8310D,E
This sounds like a control board problem.
Posted on Jan 12, 2011
mc1bean
  • 3053 Answers
SOURCE: why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Posted on Oct 21, 2011
Tip
How to Install Radiant Heat
Over the past twenty years plus,radiant heating has come to be a very acceptable way of heating. I have watched this heating become more and more popular every year. I also have seen many jobs where people do it all wrong and then wonder and get upset because this latest and greatest "state of the art" heating system does not perform properly or save them any money.
Radiant heating is best known for the fact that it is one of the most comfortable heating systems. The next best thing about radiant heating is the efficiency that it provides. Unfortunately there are way too many systems that are installed without efficiency in mind. They really do not peform any better than any other hot water heating system. This deprives the homeowner of one of the most important benefits of a radiant heating system.
The biggest mistake that people make is that they think they can install a radiant heating system for the same amount of money as any other hot water heating system. Nothing could be farther from the truth. If anyone ever tells you that they can do that run as far and as fast away from them as you can! A properly installed radiant heat system will cost you more money! The benefits will offset that, but you must spend the money upfront. Also, just installing a high efficiency boiler does not give you a high efficiency heating system. A great heating system involves much more than just a high efficiency boiler!
To have a radiant heating system that will perform efficiently you have to install radiant heat plates under your tubing, install the radiant tubing in a gypcrete or concrete pour, or install your tubing in a specially prepared sub floor. These methods will allow you to heat your home or building with very low temperature water. Low temperature water is whre you get your high efficiency. If you have to turn up the temperature of the water to get the heat out of the pipes and into the room you are then fighting a losing battle.
So, if you are considering a radiant heating system there really are only three considerations for you. Good quality radiant heat plates that attach to the sub floor with a reflective insulation under them to give the radiant heat the signal to go up. Pouring the radiant tubing into the concrete of a basement floor, or gypcrete (light weight concrete), over the sub floor of upper floors. In either instance make sure that you use a good quality insulation under the floor. Insulation for radiant systems is another topic that I will have to cover in a future article. Thirdly, there are products made that are specifically made to be incorporated into the sub floor that accept the radiant tubing. Grooves are cut into the sub floor and the tubing is inserted into the grooves. Usually these products will have a type of plate and insulation incorporated into the product.
A radiant heating system can be one of the very best types of heat you can have if it is installed correctly! A correctly installed system will give you many years of dependable service with the lowest possible operating cost. It will be nearly maintenance free and trouble free, giving you many years of comfort, with no worry or fuss.
When you are looking to buy a radiant heating system look around for the company that will give you one of these options. Not just be trying to get you to buy on price. If they are cutting price to get you to buy, the chances are that they are also cutting their quality to get to that price. That will never give you the best deal when it comes to a radiant heating system.
on Dec 29, 2009 | Heating & Cooling
Tip
Radiant Heating - Why do You Feel Warm? The Best Most Efficient Heating System
What makes you feel warm on a sunny day in the summer? Radiant heating or radiant energy is usually recognized as the oldest form of heating. It provides the best comfort and is the basis for all types of heating systems. Radiant heating is "radiant energy" being emitted from any heat source. Radiant heating is the effect you feel when you can feel the warmth of the sun or a hot stove top element from across the room.
Radiant heat is widely known as the most comfortable and efficient heating method you can find. Some of the advantages of radiant heating are: it is usually more efficient than baseboard heating and almost always more efficient than forced-air heating because no energy is lost through ducts and other transfers. This technology can be used for both heating indoor and outdoor areas. These heating systems work by supplying heat directly to the floor, to panels in the wall or to the ceiling of a house. Because the radiant heating will make you feel warmer when you are in a room, you can have the thermostat at a lower temperature and still feel warm.
The feeling of warmth is the absence of heat being pulled from your body. If the walls, floors, and ceilings around you are warm then they are not pulling heat from your body. Then you feel warm. Your body is not giving up heat to them.
Because of this radiant heating systems can provide massive energy savings of more than 10-30% in most residences, and sometimes up to 60% in shops, hangars and warehouses. Radiant heating provides even warmth with no cold spots within a room. That provides a comfortable environment that cannot be matched by any other type of heating system.
New radiant systems are currently designed to run cooler than they did in the past. The water supplied to the systems will generally range from 90 to 140 degrees. Remember radiant heat can travel in any direction and is unaffected by gravity. Radiant heating systems will allow you to be more comfortable at a lower thermostat setting. Radiant heat will warm the closest and coldest mass, which then radiate heat throughout the space evenly. Radiant heating will give you the most consistent room temperatures from floor to ceiling when you compare it to any other heating system.
on Dec 12, 2009 | Heating & Cooling
New Valor Petrus electric top of fire, plus granite surround plus fire surround mantle get very hot, room does not. 's this a fault
If it doesn't have a blower, you may need to install a blower kit. It sounds like you need some air circulation in the room.
Jan 08, 2015 | Home
Tip
Underfloor Radiant Heating works great with a Geothermal Heat Pump
Radiant floor heating has been the standard for comfort and efficiency for many years. The feeling of having a warm floor under your bare feet is priceless. Rolling on the floor while playing with your children or grandchildren is great when it is cold outside and the floor is pleasantly warm.
Geothermal Heat Pumps usually are associated with hot air heating and air conditioning systems. If you live in a climate that very seldom needs air conditioning, then you need to concentrate more on the heating. There is a super way to use geothermal technology to give you very efficient and comfortable heating. Underfloor radiant heating can very easily be incorporated with a geothermal heat pump to give you the best of both comfort and efficiency.
Here are some thing’s that you do have to consider before deciding on a system like this.
You will need to drill a few wells to extract the heat from the ground.
Piping must be installed in the wells correctly for the system to work properly.
You will need a heat pump designed for hot water heating.
You can not use a heat pump that is designed for hot air use and convert it for radiant heating.
The radiant heat design must be designed to use water temperatures that are cooler than that of many radiant heat systems.
The maximum temperature design should be 130 degrees F.
To get this kind of design to work correctly for you, you will need to use good quality heat plates and insulated under the heat plates.
By following these guidelines I have designed a number of radiant heating systems that have proven to heat houses very comfortably at temperatures well below zero.
If you decide on installing this type of system make sure that your installer knows exactly what they are doing. This type of system requires many things to be done exactly right, so that the water flows will allow the system to work correctly. The piping on the well side is extremely critical so that it uses all the wells equally. On the house side the piped using a primary/secondary piping scheme. Pumps and pipe sizes need to be able to give you very high flow rates so that the temperature drop is kept to ten degrees or less. When working with these low temperatures the piping and pumping becomes so much more critical.
By using these principles you can combine two very great heating types and can have a very good heating system that will perform very well for many years. The main drawback with this type of system is that you do not have the ability to get much cooling from this system. This is probably the only drawback of this type of system. It would be wondeful if there was a geothermal unit that was heating only. The elimination of the reversing valve would be a great cost savings and a plus overall. This system is best suited for cooler climates that require little or no air conditioning.
on Dec 05, 2009 | Heating & Cooling
Tip
Geothermal Heat Pumps And Radiant Heating - An Absolutely Fabulous Combination
Geothermal Heat Pumps are usually associated with hot air heating and air conditioning. In climates that very seldom need air conditioning you need to concentrate more on heating. There is a very good way to use geothermal technology for very efficient and comfortable heating. Radiant floor heating can very easily be combined with a geothermal heat pump to give both comfort and efficiency.
Radiant floor heating has been the comfort and efficiency standard for many years. The feeling of a warm floor under your feet is priceless. Romping on the floor while playing with the children is great when the snow is blowing and the floor is pleasantly warm.
Geothermal heating has also been known for it's efficiency also. The drawback to hot air geothermal heating has been the air temperatures that are cooler than normal hot air heating systems. By combining the two types of systems you can have very comfortable heat and efficiency at the same time.
There are something’s that you do have to take into consideration before deciding on a system like this.
You will have to drill a few wells to extract the heat from the ground. The piping must be installing in the wells correctly for the system to work properly. The heat pump needs to be designed for hot water heating. You can not use a heat pump designed for hot air use and make it work for radiant heating. The radiant heat design must be figured to use water temperatures that are cooler than many radiant heat systems. A maximum temperature design should be 130 degrees F. To get this kind of design to work correctly you will have to use good quality heat plates and insulated under the heat plates. By following these guidelines I have designed systems that have heated houses very comfortably at temperatures well below zero.
If you decide to install this type of system make sure that the installer knows exactly what they are doing. This type of system requires many things to be done exactly right so that the water flows will allow the system to work correctly. The piping on the well side is very critical that it uses all the wells equally. On the house side the piping must be primary/secondary. Pumps and pipe sizes must be able to give very high flow rates so that temperature drop is kept to ten degrees or less. When working with such low temperature the piping and pumping becomes so much more critical.
By using these principles to combine two very great heating types you can have a very good heating system that perform very well for many years. The only other factor with this type of system is that you don not have the ability to get cooling from the system. That is probably the only drawback of this type of system. It would be great if there was a geothermal unit made that was heating only. The elimination of the reversing valve would be a cost savings and a plus overall. This system is best suited for cooler climates that require little or no air conditioning.
on Dec 04, 2009 | Heating & Cooling
My Valor fireplace won't turn off with the remote
Easy turn the gas cylinder close then its off,Or you could have a faulty control valve or thermo couple .Thermo couple is the small device looks like a probe to detect heat this is normally directly in the small pilot flame.The pilot flame if not burning will not open the control valve for the other burners to come on.If the other burners come on but do not go of when turned off. then need to check control valve.
Jan 06, 2014 | Televison & Video
I have an old valor homeflame fire could you tell me how tha logs are put in position please
Here's a link to the Valor website home page.http://www.valorfireplaces.com/
Click on the Downloads tab and you may find the Owners Manual for your gas fireplace. It will show you how to install and arrange the logs properly. If you can't find the model you have, on the manuals page, use their contact information and call them.
Hope this helps you.
Feb 18, 2011 | Heating & Cooling
Gas fireplace question
Simulated gas log fireplaces usually don't have a blower of any type. They depend on the radiant and conducted heat much like there was a real wood fire in the firebox. Look in the manual to determine if a blower was included, but I doubt it because of risk that CO would be propelled into the living space.
Jan 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
271 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
