Question about Epson TM-L90
??????????? printer doesn't stop printing, help!
Hi, Everytime I turn on my Epson TM-L90 printer it prints out continuous pages of; ?????????? ?????????? ?????????? ...and it doesn't stop. I have tried turning the power supply off and taking out the serial port to the PC, and even uninstalling all the drivers/software. Is there another way of resetting this printer? Any help or advice would be most appreciated! Pete
  • Peter Brewer Jul 01, 2007
    Hi CompuGuy44,
    Thanks for the response.
    It didn't work, as soon as I turn on the printer it starts to print continuously again.
    New Friend:
Look for the dip switches parameters in internet supposed to be config at 9600 speed
try dip switch 1 pos 1 on this will eliminate ????
if doesnt print switch 1 pos 1 off and switch 2 pos 7 or 8 on for the 9600
if not
change the card interface this is for serial
for the other look in https://pos.epson.com/products/ download the manual find the switches
usually the interface is bad
Posted on Nov 15, 2013
  • 432 Answers
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Posted on Jul 01, 2007
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
http://pos.epson.com/products/TM-U220.htm
http://pos.epson.com/developers/index.htm
Nov 04, 2010 | Epson TM U210PD Matrix Label Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
MY PRINTER TM U200PD DONT PRINT
i search the driver in the page http://www.yoreparo.com it is the driver thank you
Oct 06, 2008 | Epson TM U200PD Matrix Printer
Driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Jun 03, 2008 | Epson TM-L90
Epson TM-T88IV causing small margins when printing to Lexmark 250dn
PRINTER WORKS BUT prints the moment I scan a item,WHICH I DONT WANT. I WANT IT TO PRINT ONLY IF I NEED TO
Aug 03, 2007 | Epson TM-T88IV Label Printer
DIP switch positions
Found them finally Pete - this is the service manual for the printer; http://www.posguys.com/download/TML90_Peeler_TRG_RevB.pdf Check page 45 of the pdf (page2-21 of the manual) for the location of the switches, the next 2 pages for the settings a bit clearer than on my previous post. also probably worth a read through the rest, in case there are some other possible solutions - I couldn't find one but you might see something that sounds familiar. Hope this helps, still trying to find a user manual direct link, will post it if i find one :)
Jul 02, 2007 | Epson TM-L90
Printer problems...
It sounds as if the port is trying to operate a mouse - giving the ???????. If you have windows XP then go to control panel, printers and faxes, then click "add a printer". The add printer wizard starts up, click next. select the "local printer" option and make sure the "automatically detect and install....etc" option is turned off. Click next and you should be able to select printer port. If you are using the serial port COM 1 (usually the only one externally on the pc), then select it from the list and follow the wizard through to the end. Restart the PC and you should hopefully find that the port has become dedicated to the printer alone. if still problems, go to device manager, right click on the COM 1 port and select properties, it should allow you to start the troubleshooter for the port. This should help. Other operating systems will have a similar procedure. Also worth trying is to uninstall the epson drivers, restart, plug the printer in and turn it on, and see if windows will automatically install the printer without the epson drivers. If it will, then let it do it's stuff and hopefully it will work. Hope this helps :)
Jul 01, 2007 | Epson TM-L90
Epson TM-L90 Logo
341 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
