Question about Panasonic NN-P294SF Microwave Oven
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
Made in June 2006. Seems as if many people have had this same smoking issue. Tonight we microwave some corn for 3 minutes....threw in the green beans and set it for 3 minutes...hit start and after about 4 to 5 seconds smoke started rolling out of the bottom of the microwave. Took the microwave out to the garage for a retest....and sure enough...smoke rolled out of the bottom of the machine in 4 to 5 seconds each time. They say it is the inverter that is weak in these units. I am assuming this 1.5 year old microwave is history? Is it true? I had a Tappan microwave for over 11 years with no problem. What brand microwave is good to buy for durability and power(1300W+)?
  • crossi Mar 15, 2009
    Hi - I've had the same problem on my NN-H665BF. I've pulled the inverter from mine. If I find a place to buy a replacement inverter, I'll post it here.
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Posted on Nov 05, 2009
Panasonic convection oven nn-cd989s, complete power off during prebake cycle of 450 deg which was directed to remove light oil coating from manufacturing process . Now unit has no power on face panel
Check the 20 amp fuse where the power cord ends inside the oven. If it is open check the latch switches. If the switches check ok the invertor is probably bad, smoking.
Dec 20, 2014 | Panasonic Genius Prestige NN-CD989S -...
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
It is smoking. Could this be the magnatron or is my microwave toast?
It really depends why it is smoking.
I, due to the model number, suspect the invertor board, but it could be all sorts.
Call an aproved engineer and get it checked.
Mar 16, 2011 | Panasonic NN-S541 Microwave Oven
Microwave does not heat.
HI, this is an inverter board issue. the magnetron would not shut down the unit. if the magnetron was the issue, it would continue to run but, it would not heat.
replace the inverter asap.
Jun 17, 2009 | Panasonic Microwave Ovens
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Turn on, but I don't har fan and it startd smoking.
I would suspect a problem with the high-voltage inverter.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 19, 2007 | Panasonic NN-T654SF Microwave Oven
Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
Oct 20, 2007 | Panasonic NN-T694SF Microwave Oven
Microwave Ovens Logo
1,684 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
