Question about Exercise & Fitness
Vitesse endurace xt front roller rubber balloned
The rubber on front roller has ballooned and is making treadmill jump
  • fisher_t2
    fisher_t2 Jan 11, 2013
    Thanks, but it is the rubber on the front roller that has ballooned an does not fit tightly to roller
    Top Expert:
  • 12,223 Answers
See the video and fix it . LUBE the rollers bearings too.
God bless you
Posted on Jan 09, 2013
Asi image pro 2 treadmill repairer
Its possible that the rubber V belt that drives the treadmill anticlockwise via the front belt roller has jumped off the motor 'driver' pulley, or the front roller 'driven' pulley, or both.
When this happens you can hear the motor, but nothing moves.
If you are not a qualified electrician, try the following, but only with the power completely disconnected and unplugged from the wall plug. Do not try the following with the power plugged in under any circumstances.
1. Unplug Power Cord.
2. Remove the screws that hold down the front engine drive belt shroud or housing cover.
3. Look for the V Belt drive and see if it has come off either pulley. It should be a small rubber V belt tightly stretched between the motor (driver) and roller (driven) pulleys.
If it is fine, maybe the motor or clutch mecanism (if it has a clutch) have burnt out or or worn out.
If it has come off, use a butter knift to leverage it back onto the pulleys while gently rotating the Pulleys.
4. Replace the shroud or motor cover with all screws.
5. Only then plug in the powercord and try it again.
Tom
Jan 30, 2014 | Acer Computers & Internet
What does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Apr 03, 2013 | Exercise & Fitness
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
Front rollerhas is rubber coated and the rubber has started to break up ,model is cyclone sx 9.0 max pro
This is a common problem with front roller that utilizes a coating that you described. Treadmill Doctor.com has these sleeves for icon fitness units they may work for your unit give them a shout they are in the state of Tennessee USA.
Aug 13, 2010 | Cyclone Folding Treadmill
Removing the front roller on a pro-form 575TL
That sleeve has had it replacing the the front roller will cost you $102.95 plus S/H and tax or got to Treadmill Doctor and they can replace the sleeve for 49.95 plus S/H and Tax and final option you can order the kit for 29.95 Plus S/H and tax and do it yourself. they can be reached @ 1-800-750-4766
May 15, 2010 | Sears Exercise & Fitness
Front roller spare part for Vitesse Treadmil
In most cases when a product is discontinued and manufacturer no longer has parts and depending on the age of the unit it will be very difficult to find parts in some case I have even gone to their vendors and come to find out that they made certain components obsolete. The only other thing I can suggest is that you take that front roller to a machine shop and if the bearings are the problem they should be able to replace them at somewhat minimal cost but . Good Luck
May 14, 2010 | Exercise & Fitness
Treadmill front roller has a rubber sleever that keep moving
That front roller's rubber sleeve by all rights should not be moving any which way. This mean the roller will have to be replaced call iconfitness @1-888-999-3756 and order a new up-graded front roller .
May 07, 2010 | RTO Image 15.0R Treadmill Walking Belt
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
