Question about Philips Televison & Video
20pt1542 58s SERVICE MENU - Philips Televison & Video
How do I exit the service menu on this TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jul 14, 2015 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Service menu codes for P42H401 plasma
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
Tip
Service menu codes hitachi misc.
PROJECTORS :
* Press the {MENU} & {RESET} buttons and then press
the {RESET} button again and hold it for at least 5 seconds.
* The Service Menu will be displayed.
* To exit, turn the Projector Off.
MISC :
1.
* Turn the TV on.
* Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} to change the data.
* Press the {EXIT} button to exit the Service Menu.
2.
* Turn the TV off.
* Press and hold the {INPUT} button on the TV then press {POWER}.
* Hold both buttons until the TV powers on
3.
* Turn the TV off.
* Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
* The letter "P" indicates picture and "A" indicates audio.
* Press the {EXIT} key to exit the Service Menu.
on Apr 29, 2015 | Hitachi Office Equipment & Supplies
What is the code to service the Samsung Rear Projection TV HCN5527W
PLEASE BE ADVISED TAMPERING WITH YOUR SERVICE MENU MAY VERY WELL COMPLETELY DISABLE YOUR DISPLAY
Turn Melody off in the user menu this allows entering the Service Menu from "power on" state without using an additional lamp cycle.
With the set off, press Mute-1-8-2-Power in quick succession.
The service menu will appear for the input you were viewing before keying the above sequence in a minute or less.
Use the CH up the CH down and the select keys to navigate the Service Menu. Press MENU to return to the main Service Menu after viewing individual functions.
Later, you will use the VOL(+) and VOL(-) keys to change the Service Menu values.
I hope that this helps you, please be carefull with this information.
asnowman
Sep 27, 2009 | Samsung Televison & Video
SERVICE MANU OF MY SANYO KIT
I HAVE A SNYO KIT ( 360 CHANNEL ) USING MICROPROCESOR IC LC863532C-58E2 I WANT TO KNOW THE CODES OF SERVICE MENU & HOW TO UNLOCK TV CHANNEL
May 31, 2008 | Sanyo DS24205 24" TV
Hidden or Service menu
thank of you but i need access to menu service please help me
please mail key to access to menu service
thanks of you
Jan 07, 2008 | LG DU-42LZ30 42 in. LCD HDTV
Entering Service Menu
OPTION MENU "MENU 0170" SERVICE MENU "MENU 0157" CONVERGENCE MENU "MENU 0159, 4 FINE, 5 COARSE, 6 MISC." By pressing Menu then #
Aug 18, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
