Question about Arrow FASTENER CO T50XP "NAIL SET ATTACHMENT" STAPLE GUN
How do you use the T-50XP Nail set attachment?
I attached it to my Arrow T-50PBN stapler, but what now? How and what do I use it on? The T-50WA is easy. Attach and staple wire/cable to a wall without puncturing it. This one is not so easy. On the side it says "BE SURE TO REMOVE ALL STAPLES/BRADS FROM TOOL BEFORE USING THIS ATTACHMENT" So, how's it going to work empty? I tried going to the Arrow web site for instructions but they had nothing! I hope to get a clue soon. Well I do have one for sure; don't buy it if you don't need it. Accessories are great if you know how/what to use it on.
    Problem Solver:
  • 17 Answers
I believe they mean remove fasteners from tool before adding this attachment, as a safety precaution so you don't injure yourself.
Posted on Mar 05, 2009
I have a power shot pro stapler model # 8000 , what size staple do I need?
You've got a good bit of choice, it will handle any of the following. 1/4-Inch thru 9/16-Inch heavy duty PowerShot and Arrow T50 staples and 9/16-Inch PowerShot brad nails
Mar 01, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
Which nailer do i need to nail down 5/8 bamboo prefinished floor i have the basic nailer for 3/4 flooring is there an attachment to add to it
Stanley makes a foot, part number MIIIFOOT-KIT, for the MIIIFS flooring stapler that prevents scratching of prefinished floors.
Jan 20, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
MY SEARS 9.6 VOLT NARROW CROWN STAPLER WILL FIRE ONE TIME OR TWO, THEN QUIT. IF I PULL THE BATTERY BACK FROM ITS LOCKED POSITION ABOUT 1/4" IT WILL FIRE EVERY TIME. GOT ANY IDEAS? I LIKE THIS STAPLER...
The terminals on the battery or on the stapler must be damaged (bent or corroded). It's probably the stapler if the battery charges fine. Does it do the same thing with another battery, or just one? Assuming it's the stapler, and you don't want to mess around with the terminals you could tape a spacer on the stapler to keep the battery 1/4 inch out. You would probably have to tape the battery in place though. If the problem is corroded terminals, I have found that a little wire brush attachment in a Dremel works great. Not a brush like a disc, but a brush that looks like the kind used for paint stenciling.
May 21, 2010 | Arrow & Professional Cordless Staple Gun
How to load Staples ?
at the rear of gun there is a small door, press in and down at the same time , it should come out ,there is a spring attached to it as well.
Apr 15, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
How to use it with nails? Is there some attachment it needs?
No attachment needed.The nails are inserted just like the staples are. You can only use the nails that are made for it of course. If you look at the front where the staples come out,there should be a little picture of a nail on one side.That is the side the nails go in, heads towards the stapler, just like the staples. The nails will only fit and function from one side of the unit.
Oct 05, 2009 | Black & Decker 5700 Powershot Forward...
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
There is a Stanley bostitch model B2000 stapler in my classroom. I need to fix the spring that advances the staples and holds them in place! wehre do connect the spring?
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
Feb 25, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
Stapler repair
Sydney 02 8004 2111 you might have to post to sydney for service
Nov 15, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Arrow FASTENER CO T50XP "NAIL SET ATTACHMENT" STAPLE GUN Logo
322 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
