Question about SanDisk 4GB microSD High Capacity Memory Card
My SD card is 4gb now its showing 30mb and I can't format
  • SanDisk Master
  • 27,725 Answers
You have to be the computers Administrator to change any values on any Hard Drive on your computer. Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control. Click start click to open on my computer you should see your Usb drive E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions. Make sure all 3 boxes are ticked full control change and read in windows 7. Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP. Click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start control panel administration tools computer management disk management right click on your usb drive select properties click tools you should see click check now click start two boxes Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive Click start click on my computer to open you should see your drive right click then select format another way Click start control panel administrative tools computer management disk management
Right click on your usb drive select format.
Hope this helps.
Posted on Jan 11, 2013
IceCake
  • 68 Answers
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
Posted on Oct 02, 2010
  • 3 Answers
SOURCE: Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
Posted on Dec 29, 2008
shbuckler
  • 126 Answers
SOURCE: Doesn't load
The reader may need re-iinstalling. or the port you are putting it in is incorrect,. try another stick to test the port or try the memory card in another PC to confirm the stick is OK
Posted on Dec 25, 2008
bunnydawg
  • 5158 Answers
SOURCE: my 4gb scan disc sd card wont format
http://www.sandisk.com/Retail/Default.aspx?CatID=1668
I believe sandisk makes a special program to format their cards
Robert
Posted on Jan 26, 2009
SOURCE: Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Posted on Feb 03, 2009
My 4gb memory card showing 30.1mb and can't formatted
My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
Jul 23, 2014 | Transcend TS4GSDHC6V 4GB Micro SDHC Flash...
Sdhc unable to format write protected
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Also, make sure the device in which you're trying to format the card is SDHC-compatible.
Jan 28, 2013 | SanDisk Extreme Hd Video Sd Sdhc 4gb...
My sd card does not show its property and doesn't format it?
normally when this occurs, its means the SD card is dead and u will need to replace it.
try connecting the sd card into a different computer or another external SD card reader. If it shows up . right click and click format. If it says it cant format it it means the card needs to be replaced.
Dec 30, 2012 | Skque 4GB MicroSDHC / MicroSD / Micro SD...
How to format when the 4gb kingmax micro sd class 4 HC can't be read
Right Click Computer, Properties, Manage, Disk Management. If it doesn't show up here the card is bad. If it shows up as Not Initialized, right click it and initialize it then right click and partition it.
Dec 21, 2012 | Electronics - Others
Just purchased a 4GB SD card and I can't take pics...says to format card how do I do that
In most camera there is a setting to do or if you put your SD card into a computer or a card reader (that plugs into a computer) and go to the 'my computer' or 'computer' part you should see the SD card there, you can right-click it and select format.
Formatting is sort of like deleting everything on the card so that a camera or device can make its own working files on it
Nov 26, 2011 | Video Game Consoles & Games
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Camera will not format sd card nor does it show a card in the camera
Something tells me that you're trying to use a brand new 4GB SDHC card. If so, your camera was designed before SDHC format came out. You'll need to use standard SD cards, those 2gb or less. Search on Amazon for "SD card 2GB". They run about 6 to 7 dollars total with shipping.
For others with similar problems, There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Samsung NV3 Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
I have been using a 4gb micro sd memory card when i format card its showing windows was unable to format & displaying 30mb size of card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Accepte my greetings
    Apr 29, 2010 | SanDisk 4GB microSD High Capacity Memory...
    SanDisk 4GB microSD High Capacity Memory Card Logo
    3,903 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
