Question about Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV FOR 110-240 VOLTS
Cannot jump to any channel
Im using sony bravia KLV-40BX450 with remote (Km-GA021). It was working perfectly. Suddenly I realized that I could to to the channel on 22 or 56 or anynumber. Just 1-9 button works & and den if I wanna go to more than 9 den I have to go by pressing next next and next. In the before I had to press 3 den a "-"(dash) button came wid it and by pressing a 6 I could able to go 36..bt now I have to press 9 & den 37 times next button to go 36.
    Top Expert:
  • Sony Master
  • 25,226 Answers
Try again using English Grammar and proper words please.
Posted on Jun 18, 2017
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
Hells Pastry
  • 6 Answers
SOURCE: Buttons won't work and it keeps freezing
On the bottom of the MP3 player there is a small hole that says "Reset" next to the USB port. Stick a pin or something inside and press the reset button. This should fix your problem. Mine had the same problem and I fixed it this way.
Posted on Nov 06, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
  • 41 Answers
SOURCE: My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
Posted on Apr 21, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
On my Sony Bravia KLV-S40A TV I have a message "VIDEO 1". How do I get it off the screen?
On the original SONY remote press display to remove that---if left on long enough it will actually burn that image into the screen--button on almost any Sony Tv remote will remove or clear it.
Oct 25, 2012 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Klv-32u300a sony geting power on suddenly goving of
SONY-KLV32U300A
NO STEND BY LED NOT LIGHT
4V FROM POWER NOT FOUND
May 01, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony Bravia Klv-32s400a Im looking for this parts Parts No A1527471G I do have this part on sale.
Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes Sony LCD tvs PCB boards.These two websites have very extensive Sony LCD tvs PCB boards.
Apr 16, 2011 | Sony KLV32S400A 32 in. LCD TV
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV FOR 110-240 VOLTS Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
