Question about Yamaha Jet Ski Pwc Cover For Waverunner Pro Vxr
Just changed the starter motor on my xl1200 limited 1999 and it's now making a grinding noise what should I do ?
Making a grinding noise after replacing the starter motor
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 14 Answers
U may have the wrong starter or it requires shims ( spacers) to adjust proper clearence.did u possibly drop or not see them when takin out?
Posted on May 03, 2013
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
Why is it making a screeching/grinding noise after starting sporadically. It has also made the noise just after turning it off.
You will need to get a helper and get under the vehicle and touch & listen to the starter while some one else starts, runs the engine, and turns the vehicle off. Is the starter loose? PLEASE BE CAREFUL WHEN YOU DO THIS SO NO ONE GETS HURT. If you determine it is the starter you will need to change the starter. Also many starters will have a solenoid right on this starter, in some cases this solenoid is between starter and the battery, follow the heavy cable (positive cable) that runs from the battery to the starter to determine the location of the solenoid. If the solenoid is on the starter just change the complete starter. If the solenoid is between the starter and the battery and the starter is determined to be acting this way then try changing the solenoid first. If it is not the starter you will want to check everything on the front of the engine, alternator, water pump, idlers, pulleys, ac pump etc. I hope this helps.
Jul 12, 2015 | Hyundai 2008 Santa Fe Limited
I have a 99 Ford Superduty 7.3 Diesel. It is making a really bad grinding/screeching sound just after it starts and is warming up. It wouldn't ******* off all the way even after the key was turned
indicates that the starter motor is stuck in the ring gear
possibly faulty starter relay or starter solenoid
pull the starter as the pinion over ride clutch is probably damaged ( noise ) and have the start circuit and relay checked
have the starter bench tested for serviceability by an accredited auto electrician
May 03, 2017 | Cars & Trucks
Starter makes a grinding noise. and wont start changed starter and have the same problem. changed crank position senser and it worked for a while. changed it again but didnt fix the problem.
if the starter is making a grinding noise when you turn the key, it's one of several possiblites. 1. Bad Starter. 2. Bad flywheel. 3. You need starter shims that fit between the starter and the motor. Most starters will bolt straight up but sometimes the gears get too close so you need to shim them apart.
May 30, 2010 | GMC K1500 Cars & Trucks
INSTALLED NEW STARTER , SOUNDS LIKE ITS NOT FULLY ENGAGING FLYWHEEL
if the starter is making grinding sound it not! however it could be loos and needs to be bolted up tight or there may be a bad power joint to the starter,, check for this also check all the earth leads off the engine to the battery, if its still grinding then its likely to be a dud starter you fitted,, the solenoid is not fully engaging the starter bog in the fly wheel teeth and it stopping short and then it spins up this is whats making the grinding noise, it can also make a right mess of your fly wheel ring gear,, so dont leave it to long to get it sorted out,
Mar 02, 2010 | 1999 Chevrolet Silverado 1500
Noisey starting vw polo had start motor changed but stiil making the same grinding noise??
possibly the ring gear(teeth on the flywheel that the starter meshes to when cranking)remove starter motor,and inspect the teeth through the hole )
Oct 18, 2009 | Volkswagen CC Cars & Trucks
Onan generator making grinding noise while cranking
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Jun 14, 2009 | Watts Onan Portable Generator - 4000 ,...
98 lesabre grinding starter
most likely your bendex wheel in the starter is not engaging the flywheel this could be due to a bad solenoid on the starter. chances are it's a bad starter, i would check to make sure all connections to starter are tight and you have atleast 11.5 -12.5 volts of current in the battery. low voltage can cause this problem as well
Aug 28, 2008 | 1998 Buick LeSabre
Yamaha Jet Ski Pwc Cover For Waverunner Pro Vxr Logo
235 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
