Question about HP Mini 1000 Mobile Broadband series PC Notebook
My lapto suddenly makes hang
When starting again nothing comes in the screen. Also shows "thermal shutdown occur"
    Master:
  • 397 Answers
It sounds like your laptop is overheating. You need to service the cooling system. To do this start by clearing all the vents of the laptop of dust and debris.
If you feel confident the next thing to do is take the laptop apart and do the same with the fans/heat sinks inside. I would also remove the heat sinks, remove any old thermal paste and re-apply some fresh paste. Then re-seat the heat sinks. If you do not feel confident in doing this it is best taken to your local repair shop and getting them to do it, Once this is done see whether the problems have been resolved by using your laptop for a while. If the problems still continue it could indicate one or more fans have failed and stopped spinning fast enough or altogether. Check this by listening to your laptop. As you use the laptop more you should notice the sound of the fan start as the laptop gets hotter and possibly speed up as time progresses. If you don't notice the fan kick in it is likely to need replacing.
Posted on Jan 09, 2013
Epson r230 sudden shutdown
Download the latest drivers for your Epson fash r230
Dec 17, 2013 | Epson STYLUS R230 InkJet Photo Printer
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
SIR MY TOSHIBA LAPTOP HANG AND SHOW LEADING INNOVATION MSG ON SCREEN AND OVER HEATING WHAT CAN I DO FOR THIS ROBLEM.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jul 11, 2011 | Computers & Internet
Hello, I have Toshiba Satellite M200 window Vista, I have a new problem after working for 10-15 mins my laptop is getting hang nothing visible on screen just blurred screen , when i switch off and start...
Your Toshiba could be overheating.
Jul 06, 2011 | Computers & Internet
HI MY LAPTOP SUDDENLY BLACK OUT AN HOUR OR TWO AGO..WHILE I'M PLAYING OFFLINE GAME. I CAN OPEN THE LAPTOP BUT THERE'S NOTHING IN THE LCD.IT'S JUST BLACK.. I TRIED TO DO ALT CRTL DEL BUT NOTHING...
Hi
I get that you was play on the notebook and it was hang and give black screen ...
please try this steps and I hope that helps you :
1- if you don't shutdown the notebook please click along on power button to shutdown the device and then open it again.
2- if you do that you must check about any voice appear when you start the device like Beep ...if there I think there's a RAM Problem or VGA.. if RAM it,s make long beep ..
3- if there is no sound thin you must note if the start up info appear in screen like Acer,CPU and RAM info , Boot info ....
4- if it appear I think you need new operating system , else may be its Video card problem ..
you can also remove the RAM and restore it may be that solve the problem.
Apr 24, 2011 | Acer Aspire 5100 Notebook
I have Acer Laptop of model Aspire 4736. the Laptop shutdown abruptly while I was working on some word file and I was not able strt it again. It was got repaired from the service centre by replacing the...
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked. You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 14, 2010 | Acer Computers & Internet
My phone suddenly shutdown and the page cannot
HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
3rd option really worked for me
Jun 21, 2010 | i-mate Jama 101 Smartphone
I have a asus striker extreme motherboard, quad core Q6600 processor, 8800 gtx graphics card, my pc was running fine suddenly it just hanged ,this has happened a few time before but after a while it starts...
Sounds like you need to go into the Bios if you know how and adjust the thermal values in there. I suggest checking heatsink on cpu is seated correctly and add a fan to increase airflow in side the case. Seems like a heat problem from what you describe.
Dec 14, 2009 | ASUS Striker Extreme Motherboard
Problem to start after shutdown
first on ur laptop. then after 1-2 sec. press F8 4-5 times ....then u will see a menu..on the top , Safe mode will b written.select it & press enter............thenwait a few min..& go to control panel--system restore...choose a restore point ,,reading the instruction & choose the date or time before the installation of that antivirus..
Jun 01, 2009 | Microsoft Windows XP Professional
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
HP Mini 1000 Mobile Broadband series  PC Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
