I have a Kenmore washing machine, model number: 110.91566200 and stock number: 15662. It will not stop filling the tub and begin to agitate. My guess is it's the sensor/switch that tells it when it has reached the correct water level. Can you shed some light on the most probable repair needed? Thank you.
  • Washing Mach... Master
  • 8,220 Answers
This is a fairly easy fix. No parts needed. The problem is with the air tight tube that goes from the bottom of the tub to the water level switch. Trash and sediment gets in the hose and won't allow the pressure to build in the tube and shut down the selected water level. Solution: remove the air tight rubber tube from the switch. Blow out the trash and sediment from the tube. Secure the tube back on the switch and pump the water out of the machine. Retry.
Note to gain access to the switch you must remove the screws holding down the console and flip it up.
Posted on Jan 21, 2009
Kenmore 80 series,CH2874165. Continues to fill with water and never starts to agitation. Will spin and drain no problem
In order for the filling to stop and the wash programme to begin, the brain needs to know there is enough water in the tub. There are a variety of methods of detecting the tub water level - pressure switch, float switch or electronic moisture detector.
These things tend to be placed outside the tub and connected by narrow hoses that sometimes perish and leak or become blocked with residue. Sometimes the switch itself fails...
May 29, 2017 | Kenmore Washing Machines
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine won't drain but it will spin.
sounds like a motor problem, the motor turns 1 way to agitate and the other way to drain and spin
Feb 16, 2010 | Kenmore Washing Machines
Kenmore Elite top load washer - agitator starts going back and forth as soon as the water starts to fill - can't get it to stop agitating while filling the tub.
Does it do it from the very beginning? There is a chance you have a bad timer. You might want a technician to do a test on the timer.
Dec 22, 2009 | Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
