Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Help is there a reset on the broiler unit when it is replaced??????
  • 61 Answers
No there is not a reset if the broil unit has been replaced and still does not work and all the wires ore conected and you have 220-240 volt coming to the oven control the control is bad and needs to be replaced
Posted on Jan 21, 2009
Is the bottom part of the double oven the broiler?
Most likely. The broiler is the central source of oven heat.
Dec 15, 2017 | Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire convection oven stopped working after self clean
Hello Margaux K - The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Nov 15, 2012 | Ovens
I have a kenmore electric stove/oven model 911.9354591. The oven does not work. When in oven mode the broiler comes on. When in broiler mode, the broiler comes on. I have replace the EOC and checked for...
You probably know this, but on an oven unit there has to be two different phases of 120 to make it work. Check the wires that attach to the oven unit to make sure that you have 240 when in oven mode. If you have only 120, find out which wire is not hot and trace it to its source. Is it miswired at the other end? Is it shorted to one of the broiler wires? Usually there is a schematic to show how the oven is wired. Check for anything that is common to both oven and broiler wires and make sure the wires are on the right terminals. With out seeing the sove it is hard to know what it going on. Hope that helps. Robin
Jun 10, 2010 | Ovens
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Want to remove broiler unit
slide on connectors would be the most likely, however occasionally you may find screw terminals or soldered joints - see if you can post us a photo and we could hopefully be sure you could also merely cut the wires next to the connectors, making sure the bare ends are properly insulated in case someone turns the broiler on at a later date by accident. Hope this helps - post back with a photo if you can :)
Mar 24, 2007 | Cadco OV-350 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
61 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
