Question about Kenmore 79203 Elite Stainless Steel 2.0 cu. ft. Countertop Microwave w/ TrueCookPlusTM Technology
Kenmore elite microwave 79203 buzzes when off
I put some food in the microwave and hit minute plus. it turned on and cooked the offd. when it turned off the buzzing did not stop. this buzzing noise always happens when it comes on but normalls stops when the microwave goes off. i tried unplugging it for a few mins and plugging it back in. didnt work. i tried letting it sit for a min or 2 to see if it would stop by itslef. didnt work. and i tried running it again and turning it off.... buzzing continued.... can anybody help me with this?
  • Kenmore Master
  • 9,047 Answers
It sounds like you have a shorted cook relay on your control circuit board.
That can usually be repaired more economically than replacing the circuit board.
Posted on Jan 10, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore microwave making loud buzzing sound.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave buzzing
It's likely a bad magnetron or maybe the high-voltage transformer. If it's within the warranty period of the magnetron (5 years or less), I would call Sears. In my professional opinion, no one should work on a microwave unless they are fully informed and aware of the deadly hazards and necessary precautions. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 23, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore over the counter microwave problem
It has a bad relay on the control board. The board will need to be replaced.
Posted on Nov 13, 2007
  • 579 Answers
SOURCE: Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
Posted on Dec 31, 2007
SOURCE: Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Posted on May 01, 2009
Why is the inside panel of my microwave rusting
There is a significant amount of steam given off during cooking. If your fan is not working or your vents are blocked, the moisture stays inside and hence; rust. You could repaint by doing a bit of sanding and using a tremclad rust paint.
Dec 13, 2014 | Kenmore Elite 79203 Microwave Oven
KENMORE ELITE #86013 Microwave/Convection Oven:Manual says always use Metal Rack when convection cooking.How can you cook whole chicken or roast? If you put food on top of the rack it will rub against
Yeah, that's an interesting dilema. You need to lift the food off the tray to get proper air circulation, but I've seen those racks and I understand that you don't have enough room to put a full bird in there! Is that by design, or an oversight? I don't know! And what can you do about that? Maybe you can cut off an inch off the support legs of the metal rack....
Oct 20, 2014 | Microwave Ovens
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
    Dec 07, 2007 | Kenmore 62622 Microwave Oven
    Microwave makes loud buzzing sound when on and no heat
    Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
    Mar 20, 2007 | Kenmore 62622 Microwave Oven
    High pitched hum/buzz
    By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
    Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
    Model 721.80803400 microwave blank control panel
    there is a transformer on front pc board.might need tech to have a looksee
    Aug 28, 2006 | Kenmore 80809 Microwave Oven
    Display Screen / Control Panel BLANK
    Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
    Aug 20, 2006 | Kenmore 80809 Microwave Oven
    Kenmore 79203 Elite Stainless Steel 2.0 cu. ft. Countertop Microwave w/ TrueCookPlusTM Technology Logo
    198 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jaime Hernandez
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
