Question about Cameras
VERTICAL LINES ON CCTV CAMERA - Cameras
    Sergeant:
  • 321 Answers
Sensor weak
Posted on Jan 10, 2013
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
How to set up cctv camera video output to Alba 19880HDF via vga input
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Aug 24, 2011 | Televison & Video
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Cctv camera wire pulled off
a simple web search for "scart socket connections" will find details of what signals each pin of a scart connector carry. however, your problem is knowing what signals the wires from your cctv camera carry. only the camera manufacturer, or a service engineer familiar with it, can tell you that.
Aug 18, 2009 | Home Security
Cctv wavy lines from camera
often problems with lines is either down to RF or if all the cameras are powered of the same psu that it could be that your psu is underated and the cameras are pulling to many amps most moden cameras rum anything from 200mas upto 1.5amps with infra red so if you only have a 500ma psu its going give up slowely
Apr 01, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Installed wireless cctv in horse stables 4 mt x 6mt dont seem to
the gain is turned up to much this is washing out the camera
another possible cause is the auto iris lens is either not set properly or stuck open.
if you are using a "bullet" camera that may not be adjustable without opening it up and removing the camera from the aluminum housing.
its usually a tiny screw that you turn up or down. could also be that the CCD or cmos image chip is dying
Mar 11, 2009 | Ktl Cctv CFB2056IR Black and White...
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Vertical lines on security camera
Sounds like a monitor that is on its way out....I would do a quick test and swap that monitor out with a different one and see it the vertical lines come back.....Let me know if this helps.....
cbinny1
Oct 22, 2008 | Home Security
Blurry vertical lines with no focus on screen
go to the sony service center for replacing the ccd image sensor....cause it is already damage l know it is free for replacing that sensor cause of production error of the sensor....
Sep 25, 2007 | Sony DCR-HC18E Mini DV Digital Camcorder
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
