Question about Samsung Shr-5162-250 16-channel Digital Video Recorder
Samsung shr 5162 the system has finished checking your hard diske and is starting up
The system has finished checking your hard diske and is starting up
Deleting vido files from hard drive
For this you will have to transfer the particular video into ur pc.. Then you can edit the video like how ever you want. you can usw sony vegas software for this.
http://www.covisec.com/product/SHR-2042/SAMSUNG_SHR2042_4_CHANNEL_DVR_STAND_ALONE_DIGITAL_VIDEO_RECORDER_TRIPLEX_250_GB.html
this is the manual for ur product
May 29, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Instructions For Fixing Hard Disk Errors
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Samsung.
Press Enter
If you get a message about "disk is locked - delay disk-check until next reboot", click OK, and shutdown/reboot Windows.
When "check-disk" has finished, any correctable errors will have been corrected.
Nov 13, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
If a file is a *.bu is it possible to view this file. Or is it possible to convert it to *.avi?
Before we convert BU to AVI, we need to figure out what is BU file format. BU files are uncommon files primarily associated with a Samsung DVR like CCTV (Closed-circuit television) recording system. Bu files contain surveillance video in a proprietary Samsung format and are playable on Samsung devices or with Samsung's video software. When you are trying to open a .BU file on Windows, Mac, media players, iOS, other portable devices, you will get the info that BU files are not supported by them.
To convert BU to AVI, we need a converting tool. Find Cicever BU Converter to have a try. It also provides a nice guide on how to convert BU to AVI here: http://www.cicever.com/how-to/bu-converter-player.html
Nov 01, 2010 | Samsung SHR-5162-250 16-CHANNEL DIGITAL...
Disk is full. Can not reset and erase the disk.
Hi !!
From your post Its not clear that either you are talking about Hard disk or Compaq disk. If its Compaq disc ( CD ) make sure its Rewriteable or if its hard drive make sure  nirtual memory is not allocated to that part and also no application or software is running.
Thanks Irfan
May 07, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
SHR-2082 RECORDING TIME ZONE FROZEN!
David,
try setting the time to something different (Like a day and hour from the current setting) than the current time and see if that come up if so then set the system to the current time and date and check again, if that solves your problem great if not reset your system and reprogram it.
Mode Key + CH 2
default value.
mj
Sep 27, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Clock battery has failed
Yes, I can to slove this problem.
I'm not english people then excuse me for my english. You need a telnet software type hyperterminal in Windows XP, a PC with serial port and a pin-to-pin serial cable. For frist time you need replace the internal battery CR2032 3V of SHR-2042 and erase all content of Hard disk. If you can't erase HD is not a big problem
Connect SHR-2042 with serial cable, open Hyperterminal and create a new connection using this setting:
Speed = 115.000
Bate bit = 8
Parity = nothing
Bit stop =1
Floe control = nothing
Save connection and run it.
Power on shr-2042 and set time and date.
Type "help" for command list
mor more istruction contact me redgerry@tiscali.it
Aug 27, 2007 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung Shr-5162-250 16-channel Digital Video Recorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
