Question about Pool & Spa
Baracuda pacer is moving to fast
It moves to fast to clean
  • 372 Answers
There is a regulator available that fits on the end of the hose in the skimmer. The more suction the wider the valve opens maintaining a consistent flow through the hose. Part #W60050 about $30
Posted on Jan 12, 2013
2 Suggested Answers
  • 106 Answers
SOURCE: Baracuda Pacer does not work. does not do
Replace diaphragm
Posted on Jan 14, 2010
Testimonial: "It is winter here now so I cant actually go test it..but in the summer the suction was minimal and it would start to vibrate a little and then stop."
My pacer baracuda turns upsige down on its back and stays like that during filtering
lay out hose straight as possible in water and see if hose has "memory" to twist one way or other , this causes swimmers to turn over , also ck speed if it's over (point) .5 inch per second then swimmer is set too fast , slow setting
Nov 07, 2014 | Pool & Spa
I cannot adjust th speed on my york pacer 3100, it just goes very fast.
I'd suspect you need a new adjustment cable and/or the winder is broken. The latter happened to my York 2500 Pacer and I replaced the cable & handle with a bike gear change mechanism.
Mar 18, 2014 | York Exercise & Fitness
Pacer not "chugging" or moving around the pool. I
the pump may have a plugged up impeller or internal part wear , i need to know what type of pump yu have, also a plugged filter may be the cause
Oct 28, 2011 | Zodiac Pacer Pool Cleaner
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
I have a baracuda pacer pool cleaner and it seems to run in the same direction and doesn't clean the whole pool how do I solve the problem
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Apr 19, 2010 | Zodiac Pacer Pool Cleaner
Baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Apr 25, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Pool & Spa Logo
24 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
