Question about Zodiac Pacer Pool Cleaner
Baracuda pacer moving to fast
Its moving to fast
  • 372 Answers
See Part # W60050
Posted on Jan 12, 2013
2 Suggested Answers
  • 106 Answers
SOURCE: Baracuda Pacer does not work. does not do
Replace diaphragm
Posted on Jan 14, 2010
Testimonial: "It is winter here now so I cant actually go test it..but in the summer the suction was minimal and it would start to vibrate a little and then stop."
My pacer baracuda turns upsige down on its back and stays like that during filtering
lay out hose straight as possible in water and see if hose has "memory" to twist one way or other , this causes swimmers to turn over , also ck speed if it's over (point) .5 inch per second then swimmer is set too fast , slow setting
Nov 07, 2014 | Pool & Spa
I cannot adjust th speed on my york pacer 3100, it just goes very fast.
I'd suspect you need a new adjustment cable and/or the winder is broken. The latter happened to my York 2500 Pacer and I replaced the cable & handle with a bike gear change mechanism.
Mar 18, 2014 | York Exercise & Fitness
Baracuda pacer is moving to fast
There is a regulator available that fits on the end of the hose in the skimmer. The more suction the wider the valve opens maintaining a consistent flow through the hose. Part #W60050 about $30
Jan 09, 2013 | Pool & Spa
Pacer not "chugging" or moving around the pool. I
the pump may have a plugged up impeller or internal part wear , i need to know what type of pump yu have, also a plugged filter may be the cause
Oct 28, 2011 | Zodiac Pacer Pool Cleaner
My baracuda classic falls on its side and stays that way being useless on the bottom of the pool. How do I solve this?
This information applies to a Baracuda G4 model only. My G4 would climb the wall at the deep end, lose suction, fall to the bottom of the pool and invariably land on its side or back.
The problem was the blue egg shaped buoy, as its called. Mine had signs of wear and there was even a hole in it. I replaced it and the G4 now works fine.
Feb 27, 2011 | Zodiac Pacer Pool Cleaner
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
I have a baracuda pacer pool cleaner and it seems to run in the same direction and doesn't clean the whole pool how do I solve the problem
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Apr 19, 2010 | Zodiac Pacer Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
47 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
