Question about Whirlpool Duet GHW9150P Front Load Washer
Replaced control pnel, not door is locked - Whirlpool Duet GHW9150P Front Load Washer
  • Ron Coons
    Ron Coons May 11, 2010
    please clarify??? whats the model and manufacture of the unit as well??
    Scholar:
  • 106 Answers
Push the 'end of cycle' button for 3 seconds- that will unlock your machine.
Posted on Mar 01, 2009
2007 Saturn ion 3 door locks fuse location
Power door lock's are controlled by the BCM - body control module . Are you familiar with automotive electronic's ?
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Front passenger door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Body control module (BCM)--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• Body control module PWR 15A fuse--Located in the body control module fuse panel, supplies power for the door lock system
Door Lock and Unlock Operation
The BCM PWR fuse supplies battery positive voltage to the BCM for the door lock system.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 1.5K ohm resistor that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
Vehicles without keyless entry have two internal drivers in the BCM to control the door lock actuators. All door lock and all door unlock. Vehicles equipped with keyless entry have three internal drivers in the BCM. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Nov 26, 2017 | Saturn Cars & Trucks
Door will not lock to start wash cycl
This sounds like a classic door lock problem. There was a design change in the lock assembly because of numerous problems.
You say you had the door replaced, did they replace the lock assy also?
The control puts power to the wax motor that operates the latch. As the door locks, the latch activates the lock switch that tells the control the door is locked.
What kind of reading are you getting on the lock switch?
Thanks/Mike
Nov 25, 2007 | Maytag Neptune MAH7500WH Front Load Washer
My right side passenger door does not lock automatically anymore. Is there a fuse that operates this.
no all is related to one fuse you can remove the door internal controls and decore and remove center lock motor plug and test two connectors with multimeter with set on 12v and then lock un lock door and check the reading of the multimeter if it read signal then all plugs and wires from central lock control unit to the door central lock unit is okay it this cae you have to replace the door central lock unit with the same if no signal is readed while you lock unlock the door then you have to check central control unit and all wire plus out of it to the door plug
2- you can remove central control unit from driver door and test it in passenger door (usually the same unit ) if it works with lock unlock its then the replaced unit is faulty and needs to be replaced if it not work then check plugs wires from central lock unit (usually found inside driver door ) to the central lock unit in passenger door
3- check signal for said door fro the output of central door unit if no signal then it mean that faulty central lock control unit
Feb 23, 2015 | 2005 Honda Accord
Liftgate not opening
You have crossed or shorting wires , Or a earth disconnection , Where current is being re routed .
Apr 05, 2014 | 1997 GMC Jimmy
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
2005 GMC blows only cold air on drivers side
Sometimes the blend air door actuators get stuck. You can usually free them by "cycling" the temperature control. For instance, If you have the control on HOT but you are getting cold air, turn the control to COLD and wait about one minute, then turn it back HOT. If this does not work, then you probably have a bad actuator on that side.
Fortunately, the driver's side actuator is pretty easy to replace. Just look up under the dash on the driver's side. The actuator is attached to the bottom of the air box. You will have to remove the lower trim pnels to see it. (See #9 in the Picture)
Aug 22, 2011 | 2005 GMC Sierra 1500 Hybrid
Locking assembly does not lock and i replaced the assembly the coil in the lock burned up. note there is a f-22 code on the mashine
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will tryto lock it six times before displaying the error code.
Possible Causes/Procedure ? Door lock mechanism is broken or removed from door.
? Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lockunit and Central Control Unit (CCU).
Since you replaced the lock assembly, I would check all the wiring connections on the CCU. What is your model number?
Jul 20, 2011 | Washing Machines
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Transmitter Programming
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
