Question about Air Conditioning and Heat for Chevrolet Aveo
Have installed a origenal aircon in chevy aveo, looking for wiring digram. (thanks)
  • Chevrolet Master
  • 1,103 Answers
How do you change an oxygen sensor on 2006 chevy aveo
There is a special socket for O2 sensors which allow the wires to stick out and not get twisted up. It's not expensive and available at most auto parts stores. Disconnect the sensor from the wiring harness, with the plug and then use the socket to remove and replace the new sensor. Re-connect electrical plug.
Please rate this answer. Thank you.
Apr 07, 2010 | 2006 Chevrolet Aveo
2004 chevy aveo radio code
I had to replace battery cable--radio now does not work without "code" --anti theft code supposedly either put in by factory or previous owner (i bought it used at car dealer), local chev dealer could not find code and was no help. am i the only one that has this problem?? other than buying new radio what can i do? thanks![/QUOTE]
Apr 05, 2010 | 2004 Chevrolet Aveo
How do I remove fuse for clock/radio '05 Aveo
I have looked and looked for this myself. I belive since one of the wires runs to the ecu. for the acc power it is branched off of some other . If you need a good reliable place to pull power. Use the power windows Breaker / fuse its on the passanger side it is on acc power for the key.
The other Direct battery feed for the radio is protected in the left fuse box on the drivers side.
Mar 31, 2010 | 2005 Chevrolet Aveo
How do you install a block heater on a chevy aveo 2006?
A block heater is installed in one of the freeze plug ports in your block. Drain your cooling system. Then drill a small hole i the center of the freeze plug and screw a self tapping screw into the hole. You can the use a claw hammer or something similar to pull the freeze plug. Then you just install the block heater in the freeze plug's place. Refill your cooling system and let it get up to full temperature checking carefully for leaks. Please rate my answer.
Dec 09, 2009 | 2006 Chevrolet Aveo
I am trying to get the wiring diagram for a 2006 chevy aveo
I believe you may run up against a inadequate ampere problem with the Aveo.. But having said that, have you tried a business that hooks up emergency vehicle lighting for advise?
Good Luck
Jun 27, 2009 | 2006 Chevrolet Aveo
Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Jun 22, 2008 | Sony CDX-CA400 CD Player
Air Conditioning and Heat for Chevrolet Aveo Logo
131 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
