Question about Tools & Hardware - Others
Im trying to figure out what model senco {air} nail gun we have. the only markings i can find on it are: fc0219(located on the top), 035/00454(located on the side) im honestly at a loss, any help will be much appreciated.
    President:
  • 1,383 Answers
When I cant find model number, I look on ebay searching for brand name ex. Senco Framer, looking at photos untill I spot the gun. Second method is to search google using brand name and selecting images only. Good luck
Posted on Jan 12, 2013
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
comax
  • 154 Answers
SOURCE: Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Posted on Apr 13, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
SOURCE: Senco nail gun was working one minute and then died...
gun nails frist nail then does not set next nail
Posted on Sep 02, 2009
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
Senco nail gun sfn30 is only firing every second nail in
You have damaged o-rings in the gun. Remove the head cap & valve assembly, remove the ring on top of the cylinder, remove the cylinder & piston. The cylinder is in tight so work it out carefully. Check the condition of the following: a split flat ring with a rubber o-ring under it on the top of the piston and two o-rings on the outside of the cylinder. If these are damaged air will leak around the piston instead of pushing it back up. The inside of the gun should be clean with a light coat of oil on everything if you are oiling it properly before use. Dirt in the gun means the gun is being laid on the ground without the air hose attached. Dry innards means no or not enough oil is being put in the gun before use. Oil pooled in the bottom of the gun means too much oil is being used. Senco doesn't make a rebuild kit for this gun, you'll have to go to the Senco website http://www.senco.com/ or other website like http://www.ereplacementparts.com to get a parts breakdown of your gun and order the o-rings (any part beginning with LB) individually. If you replace one, replace all of them and grease them up liberally when reassembling the gun.
Jan 29, 2012 | Senco Tools & Hardware - Others
Will the 901xp use any brand of papertape 33 degree nails? I have probably 12 cases of collated papertape and would hate for them to just go to waste but the 901 is not listed as compatible.
Most Senco nail guns are great about listing out brands of nails that will work with their guns, they are not particular to using their nails. The 901 does use 33 degree nails but if Senco does not list the brand that you have then I would recommend not using them so you do not damage your gun. Maybe you can sell them on Craigs List?
Hope this helps James
Apr 05, 2011 | Senco SN901XP Clipped Head Framing Nailer
Senco Framepro 602 has air coming from the top of the gun when the trigger is pulled and will not shoot the nails.
Sounds like the bar that slides down to push the nail is jamed you should disconect it from the air and check to make sure a nail is not stuck you should be able to look at the gun and see how to disasemble it in the front end to release it once that is done try some white grease on the part befor you reasemble it
Nov 20, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Framepro 602 only shoots air out a hole in the top when the trigger is pulled, occasionally shoots a nail but more often just shoots air
You have some worn out o-rings in your gun. Get a Senco repair kit #YK0360, use everything in the kit and your gun will be as good as new. Type "senco yk0360" in your search engine and shop around, the kit should be around $45 - $50.
Oct 11, 2010 | Senco Air Tools & Compressors
How to load nails into the magazine
Hi. Here are pix that show u what to do. http://www.senco.com/pdf/manuals/us/brad_nailers_11_06.pdf
be sure u are using senco headless nails and be sure the gun is upside down and that you load the nail row head first so the points are pointing out. J.
Jul 12, 2010 | Senco FinishPro 35 FinishPro 15 SLS15 3...
I have a Senco Framepro 701xp. I'm using a 3
What air pressure are you using? Try uping that, past 90 to about 105-110 max. What size air hose are you using? 1/4" is to small, need at least 3/8".
Sep 20, 2009 | Senco 2H0033N Framepro 701XP Clipped Head...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
